![]() | Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
Ah ok that's making sense now. ![]() . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3204 ![]() ![]() |
Hi Greg,
I’d give them a ring DB.
Previous Situation - DPF red Warning present/Restricted Power/DPF reading 29g of soot/LR dealer unable to force regen due to level being over 28.5g (the limit of their LR software capability)
If a LR dealer can't clear a EML then time to go.
Right, just had my car back from the LR dealer having had a red dpf light come on and not able to clear - had rear sensor replaced. They couldn’t force regen the dpf (they got lower soot readings but the engine Ecu failed to recognise the lower reading and it remained in restricted power with red light on.)
Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 332 ![]() ![]() |
That's awesome Dolphinboy. I recommend you add "number of demanded regens" to your IIDTool and maybe "total distance" too then you can see exactly when it asks for a regen as well as easily see the mileage vs the soot.
duplicate |
Roger will do |
paulparry82 Member Since: 04 Mar 2020 Location: Merseyside Posts: 21 ![]() ![]() ![]() |
Morning All
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4327 ![]() ![]() ![]() |
Step 1 is check for splits in the 4 plenum hoses. Whip off engine cover and see if you have the original |
Thanks for the response - the inlet manifold was removed and reinstalled during the coolant system works. The hoses look like the original ones judging from the photos in the link. I'll have a look to make sure clips are tight and check for any soot beenath etc.
This is addition - and after what Dr. Rob says
Thanks Greg - sorry, I thought IID was a generic term for the diagnostic tool. I bought the Icarsoft to do the battery reset when I changed the battery last year. There is an option to tell the ECU it has had a new DPF filter. Might look at the IID tool as an option, might prove useful to have.
