Home > Technical (L405) > L405 Turbo Bank A Electronic control fault & more
Page 2 of 3 <123>
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
Sebo,
I've also had good experience with my L405s (4th one now). Currently have managed a total mileage of over 90k with only one real let down, which was on my March 2013 SDV8 when the turbo hose split. All of them have been changed at around 35-40k miles. The first was absolutely brand new, the others I changed when the dealer gave me a call and says he has the right spec 10month old vehicle available.
Compare that to my last L322 which had a total of 9 weeks out of 13 in the dealer and don't even start to think back to the Classic days.
Still a bit more to do by JLR but a serious improvement.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #433321 31st Mar 2017 11:47am
Sebo
United Kingdom 2015 Range Rover Autobiography SDV8 Carpathian Grey
Hi Nick, Thanks for the input. I do think it'll get sorted, it feels like a training issue on the service/diagnostics side rather than a bad product.
I just don't want to fall into the old gamblers trap of hoping it'll be better next time!
I suppose I value reliability over almost everything else...
Update: Turbo bank B ordered to be replaced next week-another �3K if it wasn't in warranty. running total currently around �8k. Shocked !
Post #433326 31st Mar 2017 1:23pm
Nick Ground
Sebo,
you're welcome. Hopefully you will get the opportunity to properly appreciate the FFRR without further niggles.
55 D3 SE
98 MX5 1.8 RS
Post #433328 31st Mar 2017 2:03pm
Sebo
Hi All, Here's the update in case anyone comes across this issue..
Secondary turbo was found to have oil from the first turbo's leak clogging up the actuator. This caused a fault reading in the electronic control module, resulting in red triangle limp home mode.
It wasn't blowing blue smoke because the turbos were shut down by the electronically controlled waste gates.
Both turbos have been replaced along with some electrical gremlins and the remote drain recall. Total cost approx �10k if out of warranty.
I'm thinking extended warranty when mine runs out!
Hopefully all will be well for now.
Post #434026 6th Apr 2017 3:17pm
Basilfawlty
England 2016 Range Rover Autobiography SDV8 Corris Grey
Hi Sebo, I just think you've been unlucky. All of my 405's have been totally reliable (touch wood) and if you were to go back to the German cars, there is no guarantee with any of them. Good luck
Post #434030 6th Apr 2017 3:39pm
Sebo
I think you're right. I hope my experience with the turbos will help someone else out should they encounter it!
Back in love with the 405 again! Thumbs Up
Here's a piccy
Post #434060 6th Apr 2017 8:22pm
Sebo
Almost a year to the day and i have the red restricted performance triangle of doom again..
Here we go again. Confused
On the upside i did 2000 miles to/from the Alps last month with the engine light only coming on once- cycling off after the fifth re-start.
Will update when i know whats up.
Post #470864 3rd Mar 2018 6:37pm
AngelsBoy
Czech Republic
HI,
how did it all turn out? I have a bit of a problem with the turbo now
Post #563173 31st Jul 2020 9:02am
Sebo
Oil in turbo actuators bank A & B 'failures'
Hi, I went though this 3 times! If you have the same fault its characterised by getting the yellow engine warning light cycling after 5 starts to begin with followed by engine warning and red triangle with limited performance.
Basically there is a seal that fails in the engine sump from the oil sender unit that allows oil to leak into the wiring loom and via that into the turbo actuator units (which are electronically controlled). They gum up and/or short circuit.
It results in a huge amount of work and is very expensive to fix, (think 2 x turbos, wiring looms and most of the drive train has to be removed for access @ £180+vat per hour) luckily there is a revised part now to hopefully stop it happening again. There is a technical bulletin TSB01087v3. While i had full extended warranty this didn't technically cover it so you have to get your dealer to plead on your behalf...
Post #563285 1st Aug 2020 2:55pm
AngelsBoy
Czech Republic
I just got a new primary turbo twice in a row, but it was replaced by a warranty. And now I've replaced the shut-off valve on the secondary turbo. And so far, it seems to be working.
Previously you wrote: "Secondary turbo was found to have oil from the first turbo's leak clogging up the actuator. This caused a fault reading in the electronic control module, resulting in red triangle limp home mode."
How is it technically possible? That bad primary turbo can damage the secondary turbo? L405 2013 Vogue 4.4 SDV8 339.000km/211.000miles Smile
Post #563288 1st Aug 2020 3:17pm
Sebo
No its a leak from the oil sender in the sump, I think that the oil 'creeps' along the wire loom which is bundled and enclosed and therefore could go anywhere (doesn't wash away in rain etc). So it's not a leak from the turbo, but when I wrote that that was the info I was given at the time.
The turbos are, as far as I've been told, one unit i.e they don't sell the electronic control actuators separately. Im sure a specialist could separate them though.
Land Rover just chuck them back at the supplier and their insurance takes the hit I suppose. Too much hassle to take them apart.
Ask about the seal as this was the cause of the problem for me and its getting more common hence the TSB.
Post #563289 1st Aug 2020 3:28pm
LR just did this wiring TSB on mine. FOC.
The wiring which needs adapting is the oil level sensor harness. It’s a pretty simple Job to do the wiring update, basically plug and play. The part can be bought if you can’t persuade LR to do the update, it’s about £50 iirc and basically involves adding an extra plug into the harness, to stop the oil tracking down the cable. There is nothing that can't be fixed with a hammer😜😜
Post #563293 1st Aug 2020 3:59pm
Sebo
Yes thats exactly it!
I think they are catching the problem on cars now-from the sounds of it.
You're lucky, mine happened 4 years ago and was unknown problem at that time. One question why does the uprated wiring need a connector to STOP it flowing along the wires? It Shouldn't be able to leak in the first place..
Post #563297 1st Aug 2020 4:09pm
AngelsBoy
Czech Republic
Yes, I'll have it checked to see if they did it when replacing the turbo. Perhaps this is already included in the replacement service manual.
Otherwise, the actuator for the secondary turbo can be purchased separately. L405 2013 Vogue 4.4 SDV8 339.000km/211.000miles Smile
Post #563300 1st Aug 2020 4:19pm
https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf
This is what they do for reference.
So the sender doesn’t come out, I’m assuming the bit of wiring they insert stops the oil tracking. There is nothing that can't be fixed with a hammer😜😜
Post #563302 1st Aug 2020 4:29pm
Page 2 of 3 <123>
