![]() | Home > Technical (L405) > L405 Turbo Bank A Electronic control fault & more |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Sebo,
Sebo,
Sebo Member Since: 22 Mar 2017 Location: London Posts: 18 ![]() ![]() ![]() |
Hi All, Here's the update in case anyone comes across this issue..
Basilfawlty Member Since: 18 Oct 2015 Location: Cheshire Posts: 655 ![]() ![]() ![]() |
Hi Sebo, I just think you've been unlucky. All of my 405's have been totally reliable (touch wood) and if you were to go back to the German cars, there is no guarantee with any of them. Good luck |
I think you're right. I hope my experience with the turbos will help someone else out should they encounter it!
Almost a year to the day and i have the red restricted performance triangle of doom again..
AngelsBoy Member Since: 31 Jul 2020 Location: Prague Posts: 20 ![]() ![]() |
HI,
Hi, I went though this 3 times! If you have the same fault its characterised by getting the yellow engine warning light cycling after 5 starts to begin with followed by engine warning and red triangle with limited performance.
I just got a new primary turbo twice in a row, but it was replaced by a warranty. And now I've replaced the shut-off valve on the secondary turbo. And so far, it seems to be working.
No its a leak from the oil sender in the sump, I think that the oil 'creeps' along the wire loom which is bundled and enclosed and therefore could go anywhere (doesn't wash away in rain etc). So it's not a leak from the turbo, but when I wrote that that was the info I was given at the time.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8678 ![]() ![]() ![]() |
LR just did this wiring TSB on mine. FOC.
Yes thats exactly it!
Yes, I'll have it checked to see if they did it when replacing the turbo. Perhaps this is already included in the replacement service manual.
https://www.fullfatrr.com/gallery/albums/userpics/10080/N357.pdf
