![]() | Home > In Car Electronics (L322) > 2010 to 2012 satnav information gathering |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Hi,
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3803 ![]() ![]() ![]() |
Stan’s was a 2012 with dual vision, but mine is a 2011 single video screen.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35597 ![]() ![]() |
i ran mine to the rear centre console power socket ..some have piggy backed onto in the glovebox fuse panel..
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Cheers.. is it just soldered in? Or are there any adaptors for it? Current:
depends if your nav runs on 12v or 5v...if 12v then a piggy back adapter from ebay will suffice ....
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 349 ![]() ![]() ![]() |
I know this is an old thread, but I'm wanting to subscribe for notifications and thought I'd add detail to this reply too... I have a 2011 model with a single-view screen and no DVD option fitted, but it *does* have the DVD button and design as per Stans car. EDIT: Actually, I just went and rechecked and it is indeed the dualview screen, which I didn't know I had. Definitely no DVD player though ![]() |
roadnutter Member Since: 19 Sep 2013 Location: Bridge Of Weir Posts: 23 ![]() ![]() ![]() |
Hi, has anyone made any progress on this? I've got a 2012 RR and its annoying how out of date the sat nav is. No point in paying the dealer for 2014 maps. I've read other forums that it might be similar to the Volvo system where you can download updates for free. I'm not interested in a replacement system but would love to be able to make up to date maps etc if we could understand the format.
on the 2005-2009 dvd based nav the 'kwl' file has been hacked and newer mapping added but the hard disc nav cant be accessed ..
ASH Member Since: 05 Jul 2018 Location: Staffordshire Posts: 15 ![]() ![]() ![]() |
Hi Guy's, just wondering if there was any update on this?
Cudman Member Since: 28 May 2018 Location: Undisclosed Posts: 15 ![]() ![]() |
*bump*
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
WOW
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
That sounds like a good bit of research, well done. Maybe you could write the procedure hypothetically for a non brand car just to give everyone an idea of what to do so they could do their own research guided by you? |
Got a bit of overwhelming replies so decided to share a bit more.
Unlock it on that old computer using the master key, with padding MAKE A SECTOR BASED BACKUP FIRST TIME THE DISK IS CONNECTED TO OLD COMPUTER - you may need to use it if you mess up. Perform the map data manipulation needed, either upgrading the existing map region, or if you want to go deeper in the rabbit hole (another IT nerd reference) you can also change the region of the car but that requires yet more tools. Put drive back in car. The nav computer will auto-lock it back so that any additional map manipulation you may need to perform will have to start with doing the unlock step again. As said, the map data can be taken from the Volvo DVDs, do not overwrite the original LOADING.KWI nor can you ever misplace two additional files in the original map folders; MUINFIEE.BIN and UPDATE.DAT. Loose these or overwrite them and you are toast. Back to using that backup you made earlier. Cheers |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
Thanks for taking the time to explain all that, I know my way round a screwdriver and a hammer but I better not have a nibble or a bite at any of this....
