![]() | Home > Technical (L405) > Upgrade speakers |
notanrdx Member Since: 23 Jun 2020 Location: Austin Texas Posts: 37 ![]() ![]() ![]() |
I did not do any dynomat in the doors. There looks to be a bit of sound deadening material in the doors already. I did the swap myself, it was pretty quick and straightforward. I followed the Youtube guides for removing the door cards posted by powerfuluk. No surprises.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
Just to add my 2peneth to this... 6 months ago i purchased every speaker from a 2016 with Premium 24 sound system. The speakers are all carbon fibre and came from a breakers yard... So, i changed every speaker out in my car 18 speakers in total 2 in each rear panel (mid & tweeter) 3 in each door (woofer mid & tweeter) & 2 in the dash (mid & tweeter) i haven't as yet taken the drivers seat out to change the sub...
Fits perfectly under the passenger (UK RHD) seat as the floor is printed to take both/either amp... I had to modify the power lead as there is now 2 lives & 2 earths instead of one and they run 2x 80a fuses rather than 1x 40a... The sound has now gone up a further level which makes me very happy ![]() Hope this helps some of you guys ![]() |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 490 ![]() ![]() ![]() |
Is the amp this part number (LR098871)?
After reading more and checking part numbers for the 2019 RR. I will need to find a LR098875 amp. The face lift cars have different amps. |
Your biggest challenge will be upgrading the power wiring to the amplifier |
Um no! I meant 2x 80a fuses instead of the 1x 40a to the original amp ![]() ![]() ![]() ![]() This amp is what 3 times the physical size and the 24 way premium system uses 2x 80a maxi fuses to power the amp through power cabling which is a good twice as thick! |
How easy was it to add the power cables? Did you need to change the speaker plugs?
ilard Member Since: 21 Oct 2012 Location: London Posts: 713 ![]() ![]() |
Just a brief word from me. The factory 1700w Signature system is a real joy. Might even be worth £4K. So new car buyers out there: just tick the box! You’ll get over the cost (eventually). L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
Craig
Rear speakers are easy, you simply pry the speaker cover upwards and it comes out very easily... The speakers are beneath...
Martin2 Member Since: 15 Jun 2020 Location: Northamptonshire Posts: 798 ![]() ![]() |
I agree that it would be worth it. I had the B&W Diamond system in my last car which was a similar upgrade cost (£4,700) and it was absolutely fantastic. The Meridian Surround system is decent enough, but quite a step down, would have loved to have the Signature system but I didn't want to buy new this time and it's such a rare option. MY23 Panamera E-Hybrid MY19 SDV8 Autobiography - Sold |
Well the new amp is here about a week before I can get the car. So will start planning on what I need to do and the order in which I do them.
It seems that for the newer cars with the AUD4 base amps. All have the plug with the double power cable. Where can I find/get the wiring diagrams for the 2019/2020 car?
