![]() | Home > Technical (L405) > Upgrade speakers |
notanrdx Member Since: 23 Jun 2020 Location: Austin Texas Posts: 37 ![]() ![]() ![]() |
Have never done it. Here is a pic from the WM (pre 2018).
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16332 ![]() ![]() ![]() |
The above pic shows how they come off sir |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 488 ![]() ![]() ![]() |
I managed to break 2 of my trim tools but they are off and the speakers replaced...
Well better the trim tools then one of the grills I guess. |
Front doors done today. I had ordered the wrong sub and rear door upgrades they should be here Monday so next weekend.
Rear doors done today. Just the sub to go... which needs me to remove the spare wheel so I can practice with the wheel hoist...
luxmoggy, take a look at my posting re. amp swap. Its no longer a plug and play operation. |
I saw that... I might try and see... but that is a winter job... I need to finish the dashcam and to wire the android screen for the rear seats... in October we have a 2 week school holiday and we are going away in the car and they are the important bits... SDV8 AB MY 2020
Richie N Member Since: 29 Dec 2023 Location: Kent Posts: 362 ![]() ![]() ![]() |
I’m trying to find the subwoofer in mine. There’s very little info on the L405 on the net or YouTube. 🤷♂️ |
Under the drivers seat Richie, built into the floor so you’ll need to remove the seat and then all will become obvious sir… |
Thanks Craig. 👍
Which sound system do you have? Have you tried turning the sub woofer up & down to check it? Not just the bass! The sub woofer up/down in the menu?
Hi Craig,
My amp tripped out somehow just the other day! I needed to reset it and all was good again… |
