Home > Technical (L405) > Upgrade speakers
Page 4 of 4 <1234
crikey all this effort just to listen to ken bruce.... Laughing ... - .- -.
Post #711133 5th Feb 2025 4:21pm
DT8
United States 2019 Range Rover HSE 5.0 SC V8 Aintree Green
notanrdx wrote:
luxmoggy, take a look at my posting re. amp swap. Its no longer a plug and play operation.
Hi, @notanrdx, I woiuld have PM'd you but I have to make 3 posts prior to getting PM certified. It sounds like you have done the upgrades I am considering, top model speakers in doors and 825W amp. Two questions are, 1) is the amp swap plug and play on my 2019 RR [can't tell if your above comment was about pre or post facelift L405s] and 2) did you do anything with the subwoofer? I am considering abandoning the factory sub and adding a powered one in the trunk cutout.
Also considering saving myself the brain damage and letting Custom Sounds here in Austin charge me an an arm and a leg to go through the system. THX!
Post #712312 20th Feb 2025 1:44pm
goldeneye32
United Kingdom 2014 Range Rover Autobiography SDV8 Firenze Red
[img]https://www.fullfatrr.com/gallery/albums/userpics/27227/Meridian%201700W%20Sound%20System.pdf[/img]
Hoping you can see this, it should be the Meridian Signature Sounds System Press release for the L405.
(Think you can open it from my Gallery)
Post #712315 20th Feb 2025 2:10pm
mjdronfield
This work?
https://www.fullfatrr.com/gallery/albums/u...System.pdf 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #712321 20th Feb 2025 2:52pm
Page 4 of 4 <1234
