Home > Maintenance & Mods (L405) > TPMS readings
TPMS readings
I might needs a new pressure gauge, however I was checking the tyres as part of my new shiny appreciation day, and noticed that they have been set a bit high when the tyres were fitted before lockdown.
So I checked them on the dash with the TPmS monitor. They were also a bit high on there too. 2.5 on the fronts and 2.7on the rear. I let a bit out with and checked them again with my trusty PCL tyre gauge. And set them at 2.3 front and 2.5 rear.
I then checked to see what the reading was on the dash and it was still reading 2.4 front and 2.6 rear. So it seems that the TPMS reads 0.1bar higher than my gauge.
Weird. I’ve been using this for years and it’s always seemed correct.
Anyway the OCD in me has let a bit more air out and the dash now reads 2.3/2.5 in line with the recommendations. But I’m non the wiser as to which is the most accurate!!
Anyone else noticed that the TPMS reads wrong?? There is nothing that can't be fixed with a hammer😜😜
Post #561039 11th Jul 2020 7:14pm
just done the same yesterday/today Mark..
i have a digital pressure gauge and the tpms reads lower....i adjusted to the tpms yesterday and the steering didnt feel right on my outting today so I've gone back to my pressure gauge readings... ... - .- -.
Post #561044 11th Jul 2020 7:24pm
Always thought my PCL one was pretty accurate, but as it was reading high on the TPmS no big deal let a bit out... There is nothing that can't be fixed with a hammer😜😜
Post #561063 11th Jul 2020 9:11pm
How are you guys checking the pressures on your dash's???
Post #561085 11th Jul 2020 11:57pm
ignition on only, service menu, tyre pressure check .. Thumbs Up ... - .- -.
Post #561105 12th Jul 2020 8:12am
Ahh, must be a post 14 or 15MY thing Stan...... Thud
Post #561121 12th Jul 2020 12:00pm
Yep. There’s a menu for that.... Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #561176 12th Jul 2020 8:57pm
