Home > Technical (L322) > 4.2 SC - 'E' clutch
Glibbs
4.2 SC - 'E' clutch
Good morning,
4.2 SC.
The other day took it to the local LR specialist for a ‘Transmission Fault. Limited gears. . .’. This would appear after a reasonable run of say 80 miles and only at about 2 miles from home which involved narrow lanes and quite hilly. Outside of that the gearbox performed impeccably.
They preformed a software update which resulted in a quite severe jolt when going into Drive (the same with reverse) and quite violent gear changes. They think that the ‘E’ clutch has failed which basically means a reconditioned gearbox at around £2,400 and 10 hours labour.
Any thoughts, recommendations please? Range Rover 4.2 SC
2 Range Rover Classics - one from new but both rusty now.
Rover 3.5 Coupe had since new.
Subaru Legacy 3.0.
BMW K1200RS.
Post #560759 9th Jul 2020 9:22am
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
If they did a software update, I assume all the adaptions are also reset. There is a clearly defined run in process to reset adaptions and initially you do get some quite "positive" gear changes. After 100 miles of driving the adaptions should be stabilised and at that point the gearbox should behave itself. In theory!
I know when my gearbox was rebuilt we had a number of issues that had to be resolved. Each time the adaptions were reset and there was then a noticeable change in behavior at 100 miles (not always for the better!). I know for a fact the initial run involves some quite harsh changes.....bangs! Rob 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #560765 9th Jul 2020 9:39am
Glibbs
Many thanks - very useful. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #560767 9th Jul 2020 9:41am
DrRob
T&S Norman might be worth a shout to look at it for you?? Respected specialist in your region Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #560768 9th Jul 2020 9:45am
Glibbs
400-ascona,
could you elaborate on the run-in process please? Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #560769 9th Jul 2020 9:45am
400-ascona
Glibbs wrote:
400-ascona,
I don't know what the initial process involves as the garage did it for me and just advised me to drive various different styles up to the 100 mile mark. When I had problems I did try this at one point but it never really changed anything:
Shifting Adaptations:
Executing the following is highly recommended after a fluid change for improved shifting quality:
Vehicle should be at normal operating temperature, transmission shifter in normal mode not sports.
accelerate from a rest through the gears on a moderate throttle until 6thgear is engaged (about 55mph).
Release throttle and allow car to coast down almost to a halt, do not use the brake until the car is at walking pace (if the brake is used at any time whilst the transmission is above 2nd gear the adaption process for this cycle will be aborted).
Note: using a slight uphill gradient will help the car slow much quicker. If traffic conditions necessitate the use of the brakes during the acceleration or coasting process the cycle will have to be repeated.
Hold foot on brake for 15 seconds once car has come to a halt.
Repeat this process a total of 5 times
2-1 Tip in Thump
accelerate gently to 15 MPH
Briskly Decelerate using ample braking power until 1 MPH
“Rapidly” Accelerate using 50%-75% throttle
Repeat the process a total of 6 times
To be honest a ZF specialist would be better to advise on adaption reset process. Rob 05 L322 4.2SC
Lotus Carlton
Ascona 400
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Post #560772 9th Jul 2020 9:54am
Glibbs
Thanks for that information, I'll start doing that when I pick it up hopefully this afternoon. Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #560802 9th Jul 2020 2:20pm
