![]() | Home > Technical (L322) > 4.2 SC - 'E' clutch |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 ![]() ![]() ![]() |
If they did a software update, I assume all the adaptions are also reset. There is a clearly defined run in process to reset adaptions and initially you do get some quite "positive" gear changes. After 100 miles of driving the adaptions should be stabilised and at that point the gearbox should behave itself. In theory!
Glibbs Member Since: 18 Aug 2019 Location: West Somerset Posts: 113 ![]() ![]() ![]() |
Many thanks - very useful. Range Rover 4.2 SC
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
T&S Norman might be worth a shout to look at it for you?? Respected specialist in your region |
400-ascona,
I don't know what the initial process involves as the garage did it for me and just advised me to drive various different styles up to the 100 mile mark. When I had problems I did try this at one point but it never really changed anything: Shifting Adaptations: Executing the following is highly recommended after a fluid change for improved shifting quality: Vehicle should be at normal operating temperature, transmission shifter in normal mode not sports. accelerate from a rest through the gears on a moderate throttle until 6thgear is engaged (about 55mph). Release throttle and allow car to coast down almost to a halt, do not use the brake until the car is at walking pace (if the brake is used at any time whilst the transmission is above 2nd gear the adaption process for this cycle will be aborted). Note: using a slight uphill gradient will help the car slow much quicker. If traffic conditions necessitate the use of the brakes during the acceleration or coasting process the cycle will have to be repeated. Hold foot on brake for 15 seconds once car has come to a halt. Repeat this process a total of 5 times 2-1 Tip in Thump Vehicle should be at normal operating temperature, transmission shifter in normal mode not sports. accelerate gently to 15 MPH Briskly Decelerate using ample braking power until 1 MPH “Rapidly” Accelerate using 50%-75% throttle Repeat the process a total of 6 times To be honest a ZF specialist would be better to advise on adaption reset process. Rob 05 L322 4.2SC 2016 Discovery 4 Graphite Lotus Carlton Ascona 400 Volvo V70R AWD manual Suzuki 1200 Bandit Velocette Venom BMW R80/7 Daimler V8 250 Mini Cooper S Works 2006 |
Thanks for that information, I'll start doing that when I pick it up hopefully this afternoon. Range Rover 4.2 SC
