Home > Technical (L322) > Nice lighting feature? |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 863 |
Had an audi a6 recently and when you locked the car at night the driving lamps came on for a minute automatically. I'm aware that the q7 also did this and really liked it as a feature. I wonder if it would take much work to get this feature on a full fat?
22nd Mar 2011 10:05pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Er they already do , when you park up push the light stalk forwards once you turn the engine of and your head lights will come on for a pre determined length of time. 2008 MY Supercharged
22nd Mar 2011 10:11pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Yes the FFRR has this feature already is a custom option that you can have turned on or off, i have it turned on, on my car its called headlight delay and it works if the lights are on when you turn the car off the car leaves the lights on for around a minute and the car displays head light delay on the dash. This option is also called follow me home, you can also specify the time the lights stay on for. If you have a fault mate you can turn it on yourself, i used my faultmate to enable the feature if not you will need to visit a dealer. Matt |
22nd Mar 2011 10:13pm |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
yep, if my lights are on and I turn the igniton off before swithcing the lights off then they will stay on for a set period of time after I have locked the car. Thats a 2002 HSE model FFRR TD6 HSE
22nd Mar 2011 10:22pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
mine dont do this or am i doing it wrong....all that happens is my side lights stay on ...why we are on the subject of lights ,do i have auto lights as standerd i do have the xenon lights "RANGEISM WILL NOT BE TOLERATED"
23rd Mar 2011 12:46am |
Hi mate, you need to get the follow me home feature turned on to allow the main headlights to say on when you turn the engine off and turn the light switch off. On the pre 05 vehicles auto lights is not installed.... BUT you can installed it, in fact i am in the process of installing at the moment - to enable auto lights on a pre 05 range rover you need to change the LCM (Light Check Module) on pre 05 vehicles you have LCM 3 installed this will not do auto lights but you can swap LCM 3 with LCM 4 which supports auto lights. Then you need to replace the main light switch (below drivers vent) to the later one which has the extra auto lights position on the dial, and finally you need to replace the rain sensor (behind the rear view mirror, its the blue thing you can see from the outside of the car at the top of the wind screen) with the later rain AND light sensor. All these items are a straight swap and use the same connecitons e.g. plug and play. The only thing you may need to do is have the LCM 4 re-programmed to the options that are on your car e.g. xenon lights etc... you can use the LCM 4 from a BMW X5 E39 instead of one from a range rover as they are the same units. Matt |
23rd Mar 2011 8:00am |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
Hi Matt - On the LCM subject - I'm doing this upgrade to my 54 Vogue at the moment. Had a look at my LCM and it say on it YWC500280 - 4B. The LR dealer can't confirm that this is the auto version so how can I tell? Ash
23rd Mar 2011 8:39am |
kriswilson Member Since: 05 Oct 2010 Location: Aberdeen Posts: 106 |
Anyone local to Aberdeen with a faultmate want to come round and switch mine on? |
23rd Mar 2011 9:40am |
Hi mate, its easy to tell because the label will read LCM IV w/ auto lights. If it reads LCM III then you have the LCM 3 and you need LCM 4 (LCM IV) Matt |
23rd Mar 2011 2:11pm |
thanks matt keep us posted on how you get on .....ill have to add this to the long list of things i want to do.....with facelift and nav at the top "RANGEISM WILL NOT BE TOLERATED"
23rd Mar 2011 3:15pm |
I get what your saying but..... Mine has the automatic headlights and I can make them come on by flashing once after the engines off.
23rd Mar 2011 5:54pm |
again these are features that can be activated with a faultmate or a trip to a dealer. Matt |
23rd Mar 2011 8:44pm |
jonminns Member Since: 07 Mar 2011 Location: Leicestershire, UK Posts: 155 |
Are rain sensitive wipers a standard feature on Vogues around 2003?
24th Mar 2011 12:07am |
Yes all L322 Range Rovers have auto wipers. You wont miss it for long after you get your FFRR, although the L322 was actually designed by a german company BMW. Matt |
24th Mar 2011 8:08am |
