Home > Technical (L322) > Nice lighting feature?
dan_uk_1984
Worth remembering that the LCM stores a copy of the Mileage data - if you swap to an LCM from a different car you will get a "tamper" warning on the dash.
Although there are BMW tools (PA Soft) that can edit the mileage reccord I believe?
Post #56369 24th Mar 2011 8:47am
Andy
mattstevenson2005 wrote:
Hi mate, you need to get the follow me home feature turned on to allow the main headlights to say on when you turn the engine off and turn the light switch off. On the pre 05 vehicles auto lights is not installed....
Matt
Eh? I have it on my 02 Vogue. Switch the engine off with headlight switched on, rotate headlight switch to off and lights come back on for 40 seconds. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #56434 24th Mar 2011 1:40pm
jonminns
United Kingdom 2008 Range Rover Vogue TDV8 Santorini Black
jonminns wrote:
Are rain sensitive wipers a standard feature on Vogues around 2003?
None of the ones I've seen had auto lights, but I didn't check re. wipers
Ps.... i can select this feature on my golf in a menu controlled by buttons on the steering wheel, i can even select how long for and have different settings for coming/leaving home. I'll miss german common sense when i finally get hold of a FF!
Yes all L322 Range Rovers have auto wipers. You wont miss it for long after you get your FFRR, although the L322 was actually designed by a german company BMW.
Matt
Thankful it is a BMW design! Can't wait Cool
Post #56729 25th Mar 2011 10:56pm
Dolphinboy
United Kingdom 2011 Range Rover Vogue TDV8 Atacama Sand
@ Mattstevenson: pre 05 models DO have the auto lights as my 2002 HSE has it (just found out by accident!) as well as rain sensitive wipers. Also have a few Vogue features (rearheated seats) but no stanav. Crying or Very sad
Post #56732 25th Mar 2011 11:31pm
pretlove
Matt
im off outside to try it now "RANGEISM WILL NOT BE TOLERATED"
Post #56734 26th Mar 2011 12:58am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Are you sure? do you have 4 positions on the light switch e.g off, side lights, dim beam, auto lights. And do they work. If so someone has upgraded you car with auto lights as they were NOT available before the 05 upgrade. Even the top of the range 02 vogue spec did not come with auto lights nor was it a factory option, so a previous owner must have replaced the light switch, sensor and lcm ecu to the post 05 versions. All l322 range rovers have the rain sensitive wipers.
Matt
Post #56743 26th Mar 2011 8:03am
is that when i tell you where to go.... Very Happy ... - .- -.
Post #56749 26th Mar 2011 9:51am
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
axle wrote:
Er they already do , when you park up push the light stalk forwards once you turn the engine of and your head lights will come on for a pre determined length of time.
You can also enable the headlight delay manually via:-
Get in the car, lock the doors, then hold the LR button on the keyfob whilst holding the headlights on flash. Then , after a few seconds, the words 'headlight delay' will appear on the LCD display at which point release the headlight stalk. The delay is now enabled, but is manual in that once you've removed the key, you have to 'flash' the headlights via the stalk to trigger them. One thing I haven't tried is putting the lights on the auto setting (I never use it) to see if this makes any difference (i.e. might put them on for you when engine is turned off, I'll have to try it). Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #57491 29th Mar 2011 11:34pm
