Home > Technical (L322) > Ignition control cigar lighter sockets
vs322
Greece 2004 Range Rover HSE 4.4 V8 Java Black
Hi everyone
I want to have a BT / FM Cellphone charger permanently plugged into the front console lighter socket. However sockets are constantly live. I wish to convert them into ignition activated (position II) both for not having to unplug the device every time and for some added peace of mind (although nothing has happened since 2004 apparently).
I have perused the various threads but my rear fusebox configuration differs a bit, being similar to below (borrowed pic).
As there is nothing in Relay 2 position, not even the bridge piece, would simply fitting a relay equivalent to the three green ones, give me ignition activated sockets as desired, or is there more to be done or watch out for?
Thank you in advance
Post #558881 24th Jun 2020 6:28pm
vs322
Anybody??
Thanks
Post #559013 25th Jun 2020 6:13pm
pcourtney
sure - no problem see the thread below
https://www.fullfatrr.com/forum/topic40246.html
you will need a Green 5 pin relay off ebay - item number eBay Item No. 322418119744 £2.90
Post #559016 25th Jun 2020 6:23pm
vs322
Thank you, both for pointing me to the thread and to the correct relay.
I have already perused this thread yesterday and I'm pretty much having the same question as follows.
jjcbollen wrote:
Hi,
I have been reading the discussion and solutions concerning the 12V cigar plug with much interest.
When I look at my fusebox I do not have anything plugged into this socket (see photo).
Comparing the photo from Philips with mine, I can see no difference between the placed fuses, more specific the 20A fuse in position 1 is places with both of us. Therefore I am puzzled that when he removes the relay the power on the cigar lighters goes down..... since mine functions with no relay placed at all......
Can I plug it in anyway? or will there be damage?
And what I still have not heard is wether the relay from halfords (Halfords HEF553 Relay 12V 30A 4 PIN) is the right one......
I haven't been able to locate an answer whether I should just plug the relay or not, granted there is nothing in the R2 socket, so I'm stuck.
Post #559018 25th Jun 2020 6:32pm
pcourtney
trust me, just buy the Green relay off ebay, and plug it in the same spot as the YELLOW one that was on my photo ( last comment on the thread ) - it works - you are over complicating things, it is just a relay, you will be fine
you can test this before buying the relay, by taking one of your existing green relays - I suggest you use the top left one, and insert it in the position where my YELLOW one was, and test it out next time you start the car - and then turn it off
I have it set up this way for my Garmin Sat nav Smile
Post #559022 25th Jun 2020 6:37pm
vs322
Thank you for the guidance and reassurance. I'm just done restoring the fat lady in her rightful glory and I was afraid of accidentally frying something... Embarassed
Post #559025 25th Jun 2020 6:43pm
vs322
Update
After removing the lower left relay (heated rear window) and plugging it into the cigar lighter R2 relay socket (right above), nothing changes. The sockets still remain live even with the key removed.
I must point out that unlike other configurations seen where the mere relay installation did the trick, in my particular case there is neither the yellow dummy relay nor the bridge piece in the R2 socket.
So there must be more to this in order to have the sockets come live only while the ignition is on.
Any advice appreciated.
Post #559186 27th Jun 2020 6:37am
It appears that your cigar lighter sockets are directly wired from the fuse board and not either provided with the option of using a fixed link or fed through a relay.
This is an arrangement used by LandRover for cars supplied to "some markets"
There is a way to get round this to achieve what you require if you are up for a bit of improvisation.
Initially can you pull out Fuse 1 on the rear fuse board, it's 20A and is the left hand fuse whilst looking at the board.
I think removing it will cut off the cigar lighter sockets.
Can you confirm this is the case.
Post #559201 27th Jun 2020 9:20am
vs322
Hello,
Indeed, removing the leftmost 20A fuse cuts off the sockets.
I think you are correct in your assessment that they are directly wired through the fuse.
Which is surprising as it's the only car I've owned with always live cigar lighter sockets. I thought they all came as ignition switched with the exception of those located in the boot.
Post #559204 27th Jun 2020 10:09am
Ok, if you want to go ahead with modifying things to make the front socket ignition controlled let me know and I will make up a set of instructions for you. Nothing difficult, it can all be done in the rear compartment.
You will be able to reuse the 5 pin relay you have bought. Thumbs Up
Post #559212 27th Jun 2020 10:46am
vs322
Thanks, so very kind of you, I appreciate it.
I'll be using the heated rear window relay for testing while waiting for the one I've purchased from ebay.
Post #559218 27th Jun 2020 11:28am
Ok, give me a few hours to fit it in. Thumbs Up Very Happy
Post #559221 27th Jun 2020 11:46am
vs322
At your convenience. Thumbs Up
Post #559227 27th Jun 2020 12:34pm
Here you go, if you have any questions just ask. Thumbs Up
HOW TO CONVERT FRONT CIGAR SOCKET TO IGNITION CONTROL ; 2002 to 2005 vehicles
Materials. : 12V 4 or 5 pin 30A relay, 1m of 20A cable, 1m of 5A cable, various 20A spade connectors, cable connectors, insulating tape, heat shrink insulation or self amalgamating tape as you feel happy with.
The first thing you need to do is remove Fuse 1 20A on the rear fuse board and Fuse 5 5A on the front fuseboard.
You now need to find the white plug above the relays on the rear fuseboard that has a Red/ Black/ yellow banded cable as per the picture below.
The cable you want is 2nd from left and is Red/ Black/ with feint yellow banding on it.
This cable feeds the front cigar socket.
Disconnect the white plug to give yourself a bit of working room.
Follow the cable away from the plug and you should find a spot that you are happy to cut it.
Cut the cable, bare the ends and connect an extension cable to each cut end and run the extension cables to connect with terminals 30 and 87 respectively, as per drawing below.
You then need to find the Green/ Yellow ignition operated cable, this is in the wiring harness above the rear fuse board with the large red cable in it as per photo below.
Find a convenient point for yourself on the cable and connect to it a length of your new 5A cable and insulate the joint.
The other end of this new cable should be connected to terminal 85 of your relay.
This is a photo of a connection I made earlier.
You will then need to connect a length of 5A cable to terminal 86 of your relay and connect the other end to convenient earth point.
A bolt head into metalwork at the top of the compartment opening will work.
Do a quick check, reinsert the two fuses and white plug, your cigar socket will now be ignition controlled.
Now just tidy up the wiring and mount the relay if required
This should give you everything you need. Thumbs Up
Post #559267 27th Jun 2020 6:18pm
vs322
Wow! Hats off to you, sir! I could have never figured this out by myself and I'm grateful you took the trouble to write this all up. It's all crystal clear. I will locate the cables tomorrow and do the necessary shopping during the week. Then I can hopefully get it all donenext Saturday. Wink
Post #559276 27th Jun 2020 7:15pm
