Home > Technical (L322) > Ignition control cigar lighter sockets |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 586 |
Hi everyone
24th Jun 2020 6:28pm |
Anybody??
25th Jun 2020 6:13pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 821 |
sure - no problem see the thread below
25th Jun 2020 6:23pm |
Thank you, both for pointing me to the thread and to the correct relay.
I haven't been able to locate an answer whether I should just plug the relay or not, granted there is nothing in the R2 socket, so I'm stuck. |
25th Jun 2020 6:32pm |
Thank you for the guidance and reassurance. I'm just done restoring the fat lady in her rightful glory and I was afraid of accidentally frying something... |
25th Jun 2020 6:43pm |
Update
27th Jun 2020 6:37am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
It appears that your cigar lighter sockets are directly wired from the fuse board and not either provided with the option of using a fixed link or fed through a relay.
27th Jun 2020 9:20am |
Hello,
27th Jun 2020 10:09am |
Ok, if you want to go ahead with modifying things to make the front socket ignition controlled let me know and I will make up a set of instructions for you. Nothing difficult, it can all be done in the rear compartment.
27th Jun 2020 10:46am |
Thanks, so very kind of you, I appreciate it.
27th Jun 2020 11:28am |
Ok, give me a few hours to fit it in. |
27th Jun 2020 11:46am |
At your convenience. |
27th Jun 2020 12:34pm |
Here you go, if you have any questions just ask.
27th Jun 2020 6:18pm |
Wow! Hats off to you, sir! I could have never figured this out by myself and I'm grateful you took the trouble to write this all up. It's all crystal clear. I will locate the cables tomorrow and do the necessary shopping during the week. Then I can hopefully get it all donenext Saturday. |
27th Jun 2020 7:15pm |
