![]() | Home > Maintenance & Mods (L322) > Second Turbo drain mod [down south] |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
Rovertune in Reading has been mentioned before, not sure if that's going to be any good to you though looking at your location 2011 TDV8 Vogue SE |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
JLR are not interested, dont waste your breath, potentially I suppose a group action would have been the way to do it, it's clearly a design fault.
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
dennij: Rovertune was the other name that cropped up but there's something in the back of my mind that says they weren't 100% keen on doing this, but I maybe proved wrong.
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Rovertune won't do it. I reported that on here |
I'd go Green Oval if I were you. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
The first time I towed my caravan (Bailey Senator Wyoming) before the drain mod was done I spent most of my trip cleaning the bloody oil off it from the car, it was royal nightmare. After the mod, no issues.
That's looking the best bet so far.
Just out of curiosity, what has made you decide to have the turbo mod done? I'd be interested in costs and what improvements you notice if you go ahead and get it done 2011 TDV8 Vogue SE |
Bit of a long story.....had the FFRR 9 months now, read up on here about 'spirited driving' above 2500-2750rpm which then gives a good indication on whether your car needs the drain mod.
Has yours had the CSOV mod done?
Only spoken on the 'phone but think he said the 'changeover' or 'crossover' valve is the upgraded one......if that makes sense? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Yep. Easy to check but only when you know where to look. Took me about 5mins to work it out |
Update on collection of car if anyone is interested:
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
The 'italian tune up' has been discussed a lot here on the forum.
