Home > Maintenance & Mods (L322) > Front Brake Dust Shield |
BMG Member Since: 26 Feb 2019 Location: Kent Posts: 196 |
It's usually corroded around the mounting bolts and flapping about. The proper way is to buy a new ( check availability, some are no longer available new ) part, pull all the hub off, mount new shield. The other way is to get some big penny washers with an M6 hole and take up the missing corrosion hole until 5 years down the line when the corrosion is even worse, or the new owner has it.... |
11th Jun 2020 12:20am |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Thanks BMG, I would like to do it the right away (like you said by pulling out the hub) but I have not done this before so not overly confident about it which is why I was wondering if there were other ways round Current:
11th Jun 2020 12:27am |
Lot of working pulling the hub. Not the correct way of course, but some cut new shields, as per the link below, to avoid this.
11th Jun 2020 12:51am |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2656 |
Cut mine off when they did this |
11th Jun 2020 10:57am |
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 370 |
+1 Mr TEE 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
12th Jun 2020 5:59pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8626 |
Cut the narrow bit out of the new one and Fettle it round. I managed to get one off and on again when doing some bushes by cutting a bit out of it and screwing it back into place.
12th Jun 2020 6:11pm |
Perfect guys.. thanks for all the replies..
12th Jun 2020 7:19pm |
Good luck getting the hub off.
12th Jun 2020 7:54pm |
Totally, this is the main reason why I didnt go down the hub route when the lower ball joint was seized in situ 2 years ago.
12th Jun 2020 8:10pm |
Did you have a look and establish the shield is flapping about first ? |
12th Jun 2020 8:11pm |
Yeah, it's just sitting on the hub.. it looked a bit flakey when I replaced the upper and lower arms few months ago. I put it off because the local dealers didn't have them in stock. Current:
12th Jun 2020 8:24pm |
Managed to fit the dust shield today.. it was fairly easy..
18th Jun 2020 9:22pm |
Mind boggles why they didn’t just make it that shape to start with.
18th Jun 2020 9:47pm |
Totally.. I assume the 1inch metal strip makes the shield rigid.. who knows.. lol
18th Jun 2020 10:00pm |
