![]() | Home > Maintenance & Mods (L322) > Recommendations for good universal phone mount for L322 |
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 ![]() ![]() ![]() |
I made this for my 10in tablet using 5mm Aluminium Angle glues on with silicone. on the angle I bolted a camera tripod ball joint which screws into the tablet mount.
essex boy Member Since: 21 Jan 2017 Location: essex Posts: 212 ![]() ![]() ![]() |
Brodit are a good make they are car specific |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3870 ![]() ![]() ![]() |
I used one of these - worked OK.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
All those are too low down for me - I use a magnetic holder that clips into the dash-top vent.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
there is a multitude of car phone/nav holders...i'd peruse ebay and see which one is best for you.. ... - .- -.
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Are they not "phone specific" too ? 2003 Range Rover Vogue TD6 |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6743 ![]() ![]() ![]() |
Brodit do lots of different bases, that can go between panels etc. I've got 1 at either end of the dash display. On one I have my Alpine DAB control box and on the other, I have my Sat-Nav unit, so you pretty much put anything onto them.
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I spent ages trying to find one that did what you wanted. This one works well for me.
Bought one of these. Looks a little creepy but the spider legs fit in the dash mounted vents and it works a treat on the L405 and other cars I’ve tried it in:
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
I use a Spiderpodium too. Works well. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
After messing about with various models over the years I made my own, simplicity is the key. A piece of alloy u shaped stuck above the centre air vents. There is enough lean to stop your device falling back and something non-slip in the grove stops sideways movement during spirited cornering. Trust me this works brilliantly even with a 10 inch tablet
