Home > Maintenance & Mods (L322) > Recommendations for good universal phone mount for L322
Newstuart
I’m looking for recommendations for a good universal phone mount option for a 2007 L322 (my wife and I both use car and have different model phones).
I’ll be using the phones sat nav so line of sight is important and wireless charging would be a bonus
Post #557487 12th Jun 2020 8:34pm
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
I made this for my 10in tablet using 5mm Aluminium Angle glues on with silicone. on the angle I bolted a camera tripod ball joint which screws into the tablet mount.
I have a mount that fits mobiles also so it can be changed however this is in my HSE which doesn't have sat nav so use the tablet for sat nav when I need it.
The silicone allows me to remove it without leaving holes in the console
 Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #557713 14th Jun 2020 8:31pm
essex boy
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Brodit are a good make they are car specific
Post #557743 15th Jun 2020 8:23am
supershuttle
I used one of these - worked OK.
https://www.ebay.co.uk/itm/360-Universal-A...SwKp1dqStk
But it is low down not "line of sight" Geoff
Post #557761 15th Jun 2020 9:40am
GGDR
All those are too low down for me - I use a magnetic holder that clips into the dash-top vent.
The phone rests securely on the dash, will take a picture of it but it's very safe because you don't take your eye down at all, it is the same level as the speedo etc.
. Cheers, Greg
Post #557762 15th Jun 2020 9:44am
there is a multitude of car phone/nav holders...i'd peruse ebay and see which one is best for you.. ... - .- -.
Post #557773 15th Jun 2020 10:32am
Brian Considine
Are they not "phone specific" too ? 2003 Range Rover Vogue TD6
Post #557775 15th Jun 2020 10:56am
Brodit do lots of different bases, that can go between panels etc. I've got 1 at either end of the dash display. On one I have my Alpine DAB control box and on the other, I have my Sat-Nav unit, so you pretty much put anything onto them.
https://www.brodit.co.uk/brodit/vehicles/L...?steer=rhd Got - 2017 SDV8 Autobiography in Loire Blue
Post #557790 15th Jun 2020 12:55pm
kooky_guy
I spent ages trying to find one that did what you wanted. This one works well for me.
 2010 4.4 TDV8 Vogue SE
Post #557805 15th Jun 2020 2:37pm
pld118
Bought one of these. Looks a little creepy but the spider legs fit in the dash mounted vents and it works a treat on the L405 and other cars I’ve tried it in:
Breffo Spiderpodium Flexible Grip Universal Car Holder & Desk Stand Black:
Post #557845 15th Jun 2020 9:47pm
Nick591
I use a Spiderpodium too. Works well. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #557855 15th Jun 2020 10:37pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
After messing about with various models over the years I made my own, simplicity is the key. A piece of alloy u shaped stuck above the centre air vents. There is enough lean to stop your device falling back and something non-slip in the grove stops sideways movement during spirited cornering. Trust me this works brilliantly even with a 10 inch tablet
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #557865 16th Jun 2020 7:05am
