![]() | Home > Maintenance & Mods (L322) > What type of jack do you use? |
I've always liked the idea of those, but dont they damage the sill? I dont think I could use them becaue I have side steps. I saw a RR Sport try to use one and it broke the trim off the bottom of the doors.
Larry Member Since: 03 Dec 2008 Location: East Midlands Posts: 262 ![]() ![]() ![]() |
With a little mod to the pad on a standard trolley jack you can add a few inches to it. Just extend the pad so the starting height at rest is closer to the jacking point. You could even cut the top off the comedy LR jack and attach it to the top of the trolley jack to allow you to use the jacking points.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6372 ![]() ![]() ![]() |
In the RR Classics they always used to supply a good sturdy bottle jack with an adjustable crown that had a Y piece on the top for sitting under the axles - it was so simple in those days!
ken Member Since: 22 Aug 2008 Location: On another forum Posts: 936 ![]() ![]() ![]() |
Dan The Exhaust jack spreads the load over a wider spectrum in the car and the ground. They are really the only option off road & in the sand. Always chock the wheels on the other side caus they can roll.
Workshop manual says to lift everywhere but the "customer jacking points" unless on a propper four point lift.
Hi Dan what MY is your manual for I use LR GTR I agree with what you say but most users on here are customers as oppose to tech's for the front jacking point it requires the removal of an undertray on mine, so devils avdvocate how do remove the tray ( go underneath an unsupported vehicle I guess well no fffeeing way)
Ken,
Dan it doesn't say that actually, it states: "Do not position jack or stands under the following components: 1.Body structure OTHER than the customer jacking points" So it is saying you can jack on the customer jacking points. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
The TD6 engine tray is much larger on mine too, any access to the subframe requires removal, which is 6 bolts.
Adam its an Air Spung car that self levels when it wants to OK if you are smaller than a small thing however thats not me |
Yes, agreed it says the cust' jacking points as well, I was being overly dramatic in their initial exclusion. But, by body structure other than jacking points what it means is "not in the middle of the sill...." not you should only use these to lift the vehicle. The only time it says to use the customer jacking points is whilst on a lift or whilst using the factory jack. When using axle stands or other jacks use the designated points. ![]() |
If you leave a passenger door open, it will not lower. You could also disconnect the battery (as the wsm says to on prety much everything ![]() I wouldnt do major work under the car unless it was supported, although I have done things like change the oil in off road mode with a door open, and something in the way so it cant blow closed! ![]() |
This thread has been infected by the Health and Safety virus! Discovery 4 HSE
We dont want a squished Mod now do we |
