Home > Maintenance & Mods (L322) > What type of jack do you use?
Page 2 of 4 <1234>
Ivan
Ireland 2005 Range Rover Vogue SE Supercharged Zermatt Silver
I'm with Ken, I use a 2 post, 4 point Laughing lift and dread the day I have to use the standard jack. My P38 had a much more suitable bottle jack. I seem to remember reading somewhere, in either a hand book or possibly the Rave CD that Land Rover do not recomend using a 2 post lift? Regardless it is important to remember that these are heavy cars and care is needed no matter how you lift them.
Stay safe ,
Ivan FF RR S/C (Gone)
TVR Chimaera 500(Gone)
TR7 V8
Post #5533 13th May 2009 7:48am
dan_uk_1984
Wow, all that fits in the back of the car for when you need to change a wheel at the roadside? Laughing
Please guys, my point, there are safe places to lift the car from underneith, (when you dont have a two post/four post/four point lift available) that may be more suitable than the scissor jack provided by BMW.
Ken, yes I've followed BBS from "the other" forum I find his posts technically interesting, but the touting I find poor form (unless of course he is forum sponser in which case that's fine I guess)
Post #5536 13th May 2009 8:57am
Guys guys guys!
Chill!
Thanks for all the pointers, that's what the forum is for though, difference of opinion and new ideas. Sadly I don't have a full workshop and a 2 post lift.
I, like most owners will want to avoid the rubbish scissor jack and find something not too expensive but safe to use occasionally.
By the sounds of it, I need to look into a more heavy duty trolley jack.
Ken, you mentioned pumping up the air suspension to off road height first, why is that and why does it not say to do this in the owners manual?
Thanks All! Thumbs Up Discovery 4 HSE
Post #5538 13th May 2009 9:09am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Dan he is a sponsor on the Other side Thumbs Up
Post #5540 13th May 2009 9:14am
ken
Adam it does in mine
If in normal height you are jacking the cars weight from 300 or so to 500 plus in OR height your jacking from 470ish to 500 plus just makes the job easier also on mine if I jack without putting it in OR Height when I lower the car the car sits on its arse sulking
In OR Height when you jack it goes in to extended mode first and stays there when lowering also you can put it in super extended from extended as well
Strangely I have found that the FF requires a jack with a better reach than is required for the D3's Confused
Post #5542 13th May 2009 9:22am
That's the issue, finding a jack with enough lift. I don't want to spend hundreds of pounds on a full tilt workshop version, it shouldn't be necessary. Discovery 4 HSE
Post #5544 13th May 2009 9:25am
ken
Try Machine Mart Thumbs Up
Post #5546 13th May 2009 9:43am
nbunney
Ken
Bit big for carrying about though, arn't they?
Post #5547 13th May 2009 3:19pm
ken
Nope caus I dont I use an Exhaust jack if required Thumbs Up
Post #5548 13th May 2009 4:22pm
I've just gone through my owners manual AND the workshop manual, and neither of them state to put it into offroad height. They do say put it in Park, lock the steering column, chock the wheels and even put it into low range, but no mention of the suspension settings.
I would have thought that locking it in access mode would mean not having to jack it as high to get the wheel off the ground surely?
The workshop manual states that for jacking the front of the vehicle you position the jack under the centre crossmember, trouble is, I only want to jack one side at a time not the entire car!
You'd think this would be simple...... Discovery 4 HSE
Post #5549 13th May 2009 4:51pm
ken
Adam different mans then I'll scan mine in
Cross member cant see mine its under tray Thumbs Up
Post #5550 13th May 2009 4:55pm
Yeah same issue, would need to remove the engine undertray which is simple but annoying. Wonder if a 4 tonne bottle jack would be better? Even though I have a flat concrete pad to do this on, the vehicle creeps as you jack it, bottle jacks don't like that! Discovery 4 HSE
Post #5551 13th May 2009 5:04pm
Dan,
In your first 3 photos with the front of the car jacked and then on stands, the wheels are not off the ground. Is that cos you weren't doing that job that day ? Did your jack max out as it shows? Mine is doing just that. A fully inflated tyre doesn't leave planet earth with a normal 2T trolley jack. guess they are designed for mondeos etc. Discovery 4 HSE
Post #5552 13th May 2009 5:09pm
dan_uk_1984
RRUK wrote:
Dan,
I forgot to take photo's of the front so I jacked it back up, but not all the way, the axle stands go up to the next peg, then the tyre is about an inch off the ground....
At that point the jack is at it's absolute maximum and near verticle.
Dan
Post #5553 13th May 2009 5:23pm
ken
Exhaust Jack
Post #5557 14th May 2009 7:38am
Page 2 of 4 <1234>
