Home > Technical (L322) > Warm up at idle - or drive straight off? |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 |
Don't forget, marine engines can go for thousands of hours between services as opposed to just a few hundred for a car.
9th Jun 2020 12:20pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Yes, your turbos at engine idle will be spinning at 1000’s of rpm then spin up to 100,000/120,000 at full boost. Going slow out of your village/estate doesn’t do any harm to the turbos 👍 |
9th Jun 2020 2:45pm |
This is plain wrong, you can do lots of damage and have issues with all sorts of components and systems on your car leaving it to just idle instead of following manufacturers recommended ‘start and drive straight away’, emission controls, oil/fuel dilution, glazed cylinder bores, ring issues and blow by / CCV problems etc Don’t mix commercial/HGV, agricultural, Marine, race and passenger car Engineering and practices as they are very different in their intended use and operation so have evolved their own engineering/materials/lubricants/subsystems and practices to suit. |
9th Jun 2020 2:54pm |
btiratsoo Member Since: 12 May 2020 Location: Hampshire Posts: 174 |
Sadly not yet being an L322 owner, what does the owners manual state? I’m interested as being from a marine background and only owning quite vintage vehicles, series Land Rover and a 1942 lorry - no dpf/ Turbos/ emissions regs etc - I’ve entered a discussion where my knowledge runs out. This is a very interesting thread and a good discussion. Learning something new here. |
9th Jun 2020 3:26pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Clearly, you read my post incorrectly. I suggested leaving the engine to idle whilst "settling in" i.e. checking lights, wipers, seat/mirror adjustment WHY - not leaving it on idle for long. I have practised this over several vehicles all of which covered 250/350k miles without any failures or replacements like injectors. I rest my case. BTW - are the manufactures recommendations that you quote from the same manufactures that recommend not changing transmission fluids because "they are sealed for ;life" ? Any mechanical equipment that produces heat as its function or a by-product shout be warmed up & cooled off in a timly manner. 2003 Range Rover Vogue TD6 |
9th Jun 2020 3:47pm |
Roi354 Member Since: 06 Feb 2020 Location: Essex Posts: 32 |
I'm a 'seatbelt on, check mirrors then go gently' guy too.
10th Jun 2020 9:28am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 537 |
Absolutely right, the Getrag 6 speed used in the E36 M3 Evolution is a notchy old thing at the best of times, has to be treated with respect all the while. Mines on 142,000 miles now and provided you don't hurry it, it's pretty much as good as new (no lay shaft rattle either, very common on these). Drives: 2010 FFRR TdV8 Vogue - Stornoway Grey 2010 FFRR TdV8 Vogue SE - Zermatt Silver 1998 BMW E36 M3 GTII |
15th Jun 2020 10:52am |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 |
So im guessing a naughty one.
16th Jun 2020 12:13pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
I had an Alfa Romeo back in the day and it had a warning light on the dash that was red until the engine warmed up , the light would then flicker a few times and go off and you were good to go 2015 4.4 AB
16th Jun 2020 6:17pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 608 |
They can be done faster . We installed some telemetry onto a RN Frigate / Minesweeper. Engineers could get the gas turbines from cold to full power in sub 30s, useful in a pinch. Captain loved them for it, not sure what the manufacturers thought... Ed |
16th Jun 2020 7:08pm |
mgrover Member Since: 03 May 2020 Location: Leeds Posts: 399 |
my car revs itself to 1200 till warm then drops to 650rpm. i just wait for that and set off. if put it into drive before it does that it'll cancel the autorev. |
17th Jun 2020 2:53pm |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 |
Seatbelt, start and go for me.
18th Jun 2020 10:13am |
