Home > Technical (L322) > Warm up at idle - or drive straight off?
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Don't forget, marine engines can go for thousands of hours between services as opposed to just a few hundred for a car.
In an emergency a marine engine can be run up in just a few minutes. Will shorten the life of components if done too often.
I tend to take off as soon as possible because I can't give the car any wellie until I get to the edge of my village. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #557074 9th Jun 2020 12:20pm
ur20v
A Trap
You should never leave the car to idle and warm up- causes all sorts of problems including to CATS, DPF’s, the oil and just about everything else. Start and drive off, all you need to avoid is going more than 1/2 the rpm limit while cold and using more than half throttle, as you put miles and heat into the engine, increase the throttle input and rpm until the oil is fully warm (different and slower than water temp) then you can run full throttle and revs as you want.
The layman always confuses old school engineering and practices along with race car engineering and practices and just general pub gossip with these ‘I warm it up at idle for 5/10/15 minutes and never had an issue comments... manufacturers tell you to drive off straightaway for very good reasons.
Your oil if within its recommend service life will fully pressurise your engine and have flow everywhere within the first couple of revolutions and seconds. The oil film and passageway/bearing distribution will have been maintained from the last time the engine ran even months later.
This is all different to a new ‘dry’ engine after build where first start needs to be managed well to get the oil around and then bed rings in, again idling is a bad thing. On the flip side, 10-20 seconds of idle at journeys end will allow the turbo to come back to idle rpm and allow the oil to dissipate heat from the turbo bearing cartilage and exhaust housing to stop oil carbonising on the bearing journals.
Stop over thinking it and causing damage and issues.
Speaking as an ex-automotive engineer and oil production and testing background as well.
Corbyn 👍
Post #557095 9th Jun 2020 2:35pm
ur20v
A Trap
supershuttle wrote:
I was just wondering if any turbos will be spinning anyway.
Yes, your turbos at engine idle will be spinning at 1000’s of rpm then spin up to 100,000/120,000 at full boost.
Going slow out of your village/estate doesn’t do any harm to the turbos 👍
Post #557096 9th Jun 2020 2:45pm
ur20v
A Trap
Brian Considine wrote:
it cannot do any harm..
This is plain wrong, you can do lots of damage and have issues with all sorts of components and systems on your car leaving it to just idle instead of following manufacturers recommended ‘start and drive straight away’, emission controls, oil/fuel dilution, glazed cylinder bores, ring issues and blow by / CCV problems etc
Don’t mix commercial/HGV, agricultural, Marine, race and passenger car Engineering and practices as they are very different in their intended use and operation so have evolved their own engineering/materials/lubricants/subsystems and practices to suit.
Post #557098 9th Jun 2020 2:54pm
btiratsoo
United Kingdom 2009 Range Rover Vogue TDV8 Buckingham Blue
Sadly not yet being an L322 owner, what does the owners manual state? I’m interested as being from a marine background and only owning quite vintage vehicles, series Land Rover and a 1942 lorry - no dpf/ Turbos/ emissions regs etc - I’ve entered a discussion where my knowledge runs out. This is a very interesting thread and a good discussion. Learning something new here.
Post #557104 9th Jun 2020 3:26pm
Brian Considine
Clearly, you read my post incorrectly. I suggested leaving the engine to idle whilst "settling in" i.e. checking lights, wipers, seat/mirror adjustment WHY - not leaving it on idle for long.
I have practised this over several vehicles all of which covered 250/350k miles without any failures or replacements like injectors.
I rest my case.
BTW - are the manufactures recommendations that you quote from the same manufactures that recommend not changing transmission fluids because "they are sealed for ;life" ?
Any mechanical equipment that produces heat as its function or a by-product shout be warmed up & cooled off in a timly manner. 2003 Range Rover Vogue TD6
Post #557105 9th Jun 2020 3:47pm
Roi354
United Kingdom 2005 Range Rover Vogue Td6 Buckingham Blue
I'm a 'seatbelt on, check mirrors then go gently' guy too.
Anecdotally when I worked on diesel trains we'd have 1,000,000 milers roll in and the complete engine/hydrostatic cradle would be removed for Rolls Royce to inspect them. Typically they'd have cylinder wall wear due to excessive idling and the cause was bore wash and oil contamination due to the engine being at a lower than operating temperature for extended periods of time.
Also anecdotally, I have a BMW 640d and my neighbour has a Mercedes 350d - mine is a straight 6 twin turbo, his is a V6 turbo. We do similar mileage (15-18k/year) but I warm and cool mine and change the oil every 10k miles. He drives his as he wishes and sticks to the manufacturer recommended oil change intervals.
My car is absolutely fine now sitting at 60k miles whereas at 38k miles, his turbo was 'hanging out of it' according to the mechanic who looks after both.
Not very scientific but reinforces my belief that cold engines shouldn't idle or be worked hard, hot components should be cooled, and above all CHANGE THE DAMN OIL!
Finally, in response to the M3 owner specifically - the other thing to be wary of in a performance car is not only the engine oil temperature but that of the gearbox. Many gearbox failures can be attributed to heavy load applied to under or over temperature gearbox oil.
I also own a Noble which uses a Mondeo gearbox originally designed to handle 200lbft. We've seen some catastrophic failures of boxes when running 420lbft or above, yet with some relatively simple adaptions they can, and do, survive 600lbft+ mostly due to maintaining the operating temperature and ensuring the lubrication is in the right place.
Post #557151 10th Jun 2020 9:28am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Absolutely right, the Getrag 6 speed used in the E36 M3 Evolution is a notchy old thing at the best of times, has to be treated with respect all the while. Mines on 142,000 miles now and provided you don't hurry it, it's pretty much as good as new (no lay shaft rattle either, very common on these). Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #557781 15th Jun 2020 10:52am
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
So im guessing a naughty one.
i get in start check my bits before moving off then the foot goes down as far i legally can.
doesnt matter if in the L322 or the D2 i have no mechnical sympathy, but on the same hand i will fix what i break so.......
yeah i should probably be gentler but i dont
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #557890 16th Jun 2020 12:13pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
I had an Alfa Romeo back in the day and it had a warning light on the dash that was red until the engine warmed up , the light would then flicker a few times and go off and you were good to go Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #557924 16th Jun 2020 6:17pm
sako243
They can be done faster Whistle. We installed some telemetry onto a RN Frigate / Minesweeper. Engineers could get the gas turbines from cold to full power in sub 30s, useful in a pinch. Captain loved them for it, not sure what the manufacturers thought... Ed
Post #557928 16th Jun 2020 7:08pm
mgrover
my car revs itself to 1200 till warm then drops to 650rpm. i just wait for that and set off. if put it into drive before it does that it'll cancel the autorev.
Post #558030 17th Jun 2020 2:53pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Seatbelt, start and go for me.
1. It has the engine management systems on it anyway to manage all that stuff. It is not like the old days where you have to do it yourself.
2. It's a 5.0V8 SC in my case, don't want to waste a gallon of fuel just letting it idle on our drive way Laughing
3. Music will start playing from my phone anyway, no intervention or fiddling required.
Post #558101 18th Jun 2020 10:13am
