Home > Maintenance & Mods (L322) > P040D-00 (2C) restricted performance |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4301 |
Keep us posted Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
5th Jun 2020 8:12pm |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 113 |
9th Jun 2020 11:04am |
Told ya Glad it's all sorted If you haven't got the upgraded thicker walled donut hoses then now's the time to get them done There is a thread on here about buying a length of silicone hose and cutting into 4 etc Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- Last edited by DrRob on 9th Jun 2020 11:54am. Edited 1 time in total |
9th Jun 2020 11:44am |
Have you checked the oil dilution figure on your IID? Max is 7 as per Dolphin's advice above. It should have come right down if you reset the service on your IID. This should always be done after an oil change or the car has no way of knowing it has "new oil" for it's calculation. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
9th Jun 2020 11:48am |
9th Jun 2020 11:50am |
I believe the mechanic did but will go and check myself, where on the Iid would I find it ? 2011 4.4 TDV8 2000 4.6 P38 1998 D1 300tdi |
9th Jun 2020 11:53am |
To Be honest, as I had managed to get the garage to look at it I stoped looking until a grown up had had a
9th Jun 2020 12:09pm |
Ahhhh found it !!
9th Jun 2020 12:29pm |
You definitely have the old donut rubber hoses,
9th Jun 2020 1:05pm |
Nice smoke
9th Jun 2020 1:10pm |
Yes !i remember it from when the manifold split. I’m just about to order some 70mm ID silicon hose and new clamps
9th Jun 2020 1:14pm |
9th Jun 2020 2:05pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
DrRob, JLR have gone back to a third version now which are back to flat again! |
9th Jun 2020 11:20pm |
Thanks Craig - on the SDV8 I assume? Are they prone to splitting?
10th Jun 2020 7:22am |
