Home > Maintenance & Mods (L322) > P040D-00 (2C) restricted performance
Page 2 of 3 <123>
DrRob
Keep us posted Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #556613 5th Jun 2020 8:12pm
kbald
Hi you could try using soapy water around the inlet manifolds yourself to check for air leaks to see if you can spot anything. Use a spray bottle of water and washing up liquid spray it all over and let the engine run or get someone to rev it and see if you can see some bubbles forming which would tell you sir is escaping. Might be worth a try as this is how I diagnosed my cracked inlet manifold. Thumbs Up Current 2007 TDV8 Vogue Buckingham Blue
Post #557009 9th Jun 2020 6:29am
Andy2986
United Kingdom 2011 Range Rover Vogue TDV8 Barolo Black
Very Happy
Well Good news! and on two fronts !!
It was as you look at the engine from the front the rear left donut.
I took the car this morning to a new (to me) garage in Dunmow (essex) about 30 mins from me.
The chap said if I got it there for bang on 8.00am he would have a quick look before he started on the other cars scheduled for today, then we could discuss the best way forwards depending on what was found.
He did a high pressure smoke test and found a small split in the left rear rubber. It was right underneath so would have been a pig to find... So I am instantly relieved it wasn't anything major. The chap tells me he doesn't have any of the donuts in stock. im not to worried as now I know what it is I could sort it relatively easily, However he then turns up with a second hand one and puts it on for me.
We were chatting about the 'service required' coming up after only 9k since last service and the overfilled oil situation and came to the conclusion that since I've only done short trips for the past 10 weeks (lock down stuff) that it was probably multiple failed regen's.
So he suggests he does an oil change. Im quite happy as I didn't want to push my luck with what was only "a quick look"
He didn't have a filter in stock but did an oil change for me there and then.
Time spent ? just under an hour !
So i booked the car in for next week for another oil change and a filter change along with a general service and for him to look at my rubbish a/c.
So when I go to settle up he wouldn't take any money from me, just said we could sort it out when I bring it in next week. How good is that ?
Superb service a very rare thing in these times...
FYI Ive no connection with the garage other than today if you are near the stanstead area and need your landrover looking at maybe give the guy a ring ?
BROADFIELDS GARAGE
HALES FARM, HIGH CROSS LANE EAST,
LITTLE CANFIELD,
DUNMOW, ESSEX
CM6 1TQ
T: 01371 872 940 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #557056 9th Jun 2020 11:04am
DrRob
DrRob wrote:
Have you checked all 4 donut hoses?
Someone on here found their leak on the under side of a donut hose.
Told ya Whistle Thumbs Up
Glad it's all sorted Bow down
If you haven't got the upgraded thicker walled donut hoses then now's the time to get them done Thumbs Up
There is a thread on here about buying a length of silicone hose and cutting into 4 etc Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557061 9th Jun 2020 11:44am
DrRob
Have you checked the oil dilution figure on your IID? Max is 7 as per Dolphin's advice above. It should have come right down if you reset the service on your IID. This should always be done after an oil change or the car has no way of knowing it has "new oil" for it's calculation. Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557062 9th Jun 2020 11:48am
Andy2986
Yup ! I know !!!
however I did learn something else as well, to replace the rear donut he removed the hole of the plastic molding/plenum lump at the rear of the engine that goes against the bulkhead, came out in seconds.....
hopefully I've attached a photo of the smoke test..... 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #557064 9th Jun 2020 11:50am
Andy2986
I believe the mechanic did but will go and check myself, where on the Iid would I find it ? 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #557066 9th Jun 2020 11:53am
Andy2986
To Be honest, as I had managed to get the garage to look at it I stoped looking until a grown up had had a
propper look !!!! 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #557070 9th Jun 2020 12:09pm
Andy2986
Ahhhh found it !!
all looks good now i think...
This has all been a bit of a distraction I could have done without, Im more of an analogue hands on kind of guy and Im in the middle of a head swap on my Disco 300 tdi at the mo.....
 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #557077 9th Jun 2020 12:29pm
DrRob
You definitely have the old donut rubber hoses,
Upgraded ones:
Post #557084 9th Jun 2020 1:05pm
DrRob
Nice smoke Thumbs Up
You can check if he reset the service interval by looking at "number of miles since last service" on the IID somewhere Thumbs Up Needs resetting after an oil change Thumbs Up
Replacement hoses thread. 70mm and cut down Thumbs Up
https://www.fullfatrr.com/forum/topic52120...p;start=15
https://www.fullfatrr.com/forum/topic49730.html?highlight=plenum
Post #557085 9th Jun 2020 1:10pm
Andy2986
Yes !i remember it from when the manifold split. I’m just about to order some 70mm ID silicon hose and new clamps
Thanks for all the help and suggestions so far. 2011 4.4 TDV8
2000 4.6 P38
1998 D1 300tdi
Post #557087 9th Jun 2020 1:14pm
DrRob
Thumbs Up Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557092 9th Jun 2020 2:05pm
Upgraded ones:
DrRob, JLR have gone back to a third version now which are back to flat again! Thumbs Up
Post #557122 9th Jun 2020 11:20pm
DrRob
Thanks Craig - on the SDV8 I assume? Are they prone to splitting? Rolling Eyes
I'll stick with good old thick ones Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #557133 10th Jun 2020 7:22am
Page 2 of 3 <123>
