Home > Maintenance & Mods (L405) > Powerful UK Black Pack trims
TTF
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Morning,
I am considering buying a Powerful UK kit of the Black Pack trims instead of painting the trims already on the car; does anyone have any experience or thoughts on the kit?
Thanks in advance. RR 3.6 TDV8 Vogue SE
NAS, 50th, SV, 90 CSW 300 Tdi
Series 2a SWB 200 Di
Post #556104 1st Jun 2020 10:27am
No experience, but another kit is mentioned on this thread
https://www.fullfatrr.com/forum/topic50051.html
Post #556105 1st Jun 2020 10:31am
TTF
Thanks for that. Looks like Powerful has good feedback as does Hawke. Cheers RR 3.6 TDV8 Vogue SE
Post #556108 1st Jun 2020 10:38am
Cagonline
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Hi,
I have an Indus Silver RR. It had the same colour mouldings. I decided to throw away subtlety and contrast the main paint with a gloss black trim.
I considered the options to, repaint or wrap, however I decided to go for a six piece lower mouldings trim from Powerful UK.
I took this decision because they areplastic injected moulded they are gloss black impregnated all the way through. So no fade, no scratches to show the original colour if they were resprayed or wrapped.
I think this was the better solution.
The Powerful UK ones are aftermarket, and of course you take a chance on the fit of some aftermarket parts. These aren’t too bad.
You would be better getting the genuine Land Rover parts they will fit better.
But I touch a chance with the aftermarket ones because I was going to do something different and that was to fit copper inserts to individualise the car even further.
I fitted these in February, and to be honest I didn’t take enough care. Resulting in an unsatisfactory fit for my pernickety expectations. So I had to remove them later and assess what had happened.
It turned out that I had been careless in locating the lower tabs into their locating slots. A few had bent over, and were preventing a flush fit (I used the cold weather as my excuse). So after rectifying that they do look alright.
It is any easy install (if you take enough care fitting them).
I’ve enclosed some photos so you can determine for yourself. I hope this helps.
Regards,
Peter
Post #556164 1st Jun 2020 6:09pm
Cagonline
Post #556165 1st Jun 2020 6:10pm
Cagonline
Updated
Post #556167 1st Jun 2020 6:13pm
Why is this bit black, is it missing something..?
 Pete
Post #556176 1st Jun 2020 7:05pm
Cagonline
Hi,
No it’s just in black, I’ve got to repaint it. It’s got deplorable side steps. It’s on the list to be painted Indus Silver.
Regards,
Peter
Post #556178 1st Jun 2020 7:11pm
You've got to love auto correct...
"deplorable side steps" How bad are they...?? lol...
It'll look much better in silver, I like the copper, it's different.. Thumbs Up Pete
Post #556195 1st Jun 2020 9:00pm
Cagonline
Hi Pete,
Yes it needs to be silver just to match the rest. The deployable steps are great, they help me get into the car easily in access mode. My legs aren’t what they used to be.
Thanks for the comment on the copper, it makes it a little unique. When I first put them on, I put the copper strip right on the front edge. But as you probably noticed it left a bigger spacing than the others. So I removed it and put in slightly inboard to normalise the spacing between them all. It’s better but not totally ideal. It’s a little awkward with the 4 slats, I think the 3 slates would would better, they are a more uniform spacing.
Thanks,
Peter
Post #556198 1st Jun 2020 9:47pm
