Home > Technical (L322) > 2008 Dash removal |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1778 |
Its a little fiddly, but you can just remove the centre trim, column shrouds and lower kick panels, and access the switch that way |
25th May 2020 4:43pm |
JPJ64 Member Since: 23 Jun 2017 Location: Newcastle upon Tyne Posts: 49 |
Did you realease the screws under the centre air vent? |
25th May 2020 6:07pm |
Both centre console side panels off
25th May 2020 6:46pm |
Simon_CSK Member Since: 13 Feb 2020 Location: Ayrshire Posts: 132 |
So it can be got at from the bottom? Current cars
25th May 2020 7:04pm |
No, need to work through the column shroud and space from the centre panel
25th May 2020 8:35pm |
Yes Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
26th May 2020 11:00am |
Mikey I take it the sill cover is pried off as I can see no fixings to undo. Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
26th May 2020 4:58pm |
Yes, held in place with 4 plastic clips |
26th May 2020 5:17pm |
Thanks easier than I thought.
26th May 2020 6:19pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1536 |
While it's apart, replace the bulbs in the upper footwell lights. I was never able to remove the lights as per the handbook instructions. Use quality bulbs or LEDs. I replaced mine with Chinese LEDs and they have gone into flicker mode (as have most of the others I replaced with LEDs from the eBay LED kit). Ron B. VK2OTC
27th May 2020 12:29am |
Mikey got there in the end. A few variations and I needed to lift the top section of the dash to get one of the speedo trims out but essentially I am ready for the new switch. As soon as it arrives I will know if my new car goes or not. fingers crossed. Can the switch be tested now that it is out with a multi meter? Current cars Range Rover Sport HSE TDV8 Range Rover TDV8 Vogue Range Rover P38 Vogue Range Rover CSK Discovery 3 HSE |
27th May 2020 12:05pm |
27th May 2020 7:07pm |
