![]() | Home > General > Fuel Filler Problem |
Turn the trigger upside down |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 ![]() ![]() ![]() |
Does that actually work??...Never had a problem with the Sport |
Dogman Member Since: 10 Dec 2010 Location: UK Posts: 174 ![]() ![]() ![]() |
& I thought it was me just being a bifta |
Works for me Jim, just make sure you hold the nozzle away from the paintwork when you turn it upside down |
Cheers.. |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Never had a problem myself, but wasn't there a thread on here somewhere before about this. I think it basically depended on which garages you went to i.e. different garages use different pump manufacturers, so if you went to say Tesco, then if it works at 1 Tesco it is probably fine at all of them as they use the same company(s) to install their petrol pumps and so the breathing systems on the nozzles are the same whereas another garages nozzles may always be an issue. I'm probably talking crap now but I did think the fill rate was down to the gun/nozzle & its control mechanism, not the car in any way. Steve
You could very well be right RRVSE but as I said never had an issue with any fiiling station in the RRS ![]() |
skavitch Member Since: 26 Jul 2010 Location: Newcastle Posts: 36 ![]() |
I had the same problem of fuelling taking forever.
That's because the RRS is ostensibly a D3, not a FFRR. Completely different fuel tank and filler neck. My D3 was never a problem but the FFRR can be a royal PITA sometimes. Depends on which garage I'm at. |
I think sainsburys is ok (fill speed wise) & I need to take a day's leave if I'm filling up @ tesco.. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
I had this issue on the TDV8, there is a known Technical Bulletin about it, and I had my fuel filler neck replaced. However, I still find some pumps just click off annoyingly, so I have no choice but to turn the nozzle upside down, then it seems to work. The only downside really is that you sometimes need a glove on each hand to prevent getting diesel on you.
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 869 ![]() ![]() ![]() |
Hey Dogman, are you an actual 'dogman'?...... (Just your terminology) My Previous RR's! 2018 P400e Autobiography 2008 TDV8 Vogue 2006 TD6 Vogue 2007 TDV8 Vogue 2007 RRS (I know, it doesn't count!) 2005 4.4 Vogue on LPG 2005 TD6 Vogue 2003 4.4 Vogue 2001 4.6 HSE 2000 2.5 DHSE 1999 4.6 HSE 1997 4.6 HSE on LPG 1995 2.5 DSE 1989 3.9 EFI classic 1988 3.5 EFI classic |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
The problem could be that you are not used to having the misfuelling device that the FFRR Tdv8 has that the D3 and RRS don't have. I don't have a problem filling at Shell or BP forecourts but do at Esso, I have also noticed that even though they don't mark them, a lot of filling stations have one or even two pumps that are higher capacity so they can handle artics and big trucks - the tank in the RR fills in about 2 minutes from one of those. Only £93 worth of fuel, you're being a miser there Jim, that's only 2/3rd's of a tank |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
I've not had a problem in my 2006 SC, have they changed the filler neck design, or does this only occur on the oil burners? |
