Home > General > Fuel Filler Problem
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Fuel Filler Problem
Filled the beast for the first time and what a pain in the arse it was!!!!...Not only did it cost �93 but it took about 8 minutes to fill up the tank as the nozzle kept cutting out if you pulled the trigger all the way up. Only way I could do it was to hold trigger half way and let the diesel trickle in Censored ...Is there a known problem with the fuel filler on the Rangie that causes forecourt fuel pumps to cut out Question
Post #55490 18th Mar 2011 10:01pm
Turn the trigger upside down
Post #55492 18th Mar 2011 10:05pm
wackyjim
Does that actually work??...Never had a problem with the Sport
Post #55494 18th Mar 2011 10:07pm
Dogman
& I thought it was me just being a bifta Embarassed
Must say when I turned the nozzle round it's much better Thumbs Up
Post #55495 18th Mar 2011 10:10pm
Works for me Jim, just make sure you hold the nozzle away from the paintwork when you turn it upside down
Post #55496 18th Mar 2011 10:12pm
wackyjim
Cheers.. Thumbs Up Thumbs Up
Post #55497 18th Mar 2011 10:13pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Never had a problem myself, but wasn't there a thread on here somewhere before about this. I think it basically depended on which garages you went to i.e. different garages use different pump manufacturers, so if you went to say Tesco, then if it works at 1 Tesco it is probably fine at all of them as they use the same company(s) to install their petrol pumps and so the breathing systems on the nozzles are the same whereas another garages nozzles may always be an issue. I'm probably talking crap now but I did think the fill rate was down to the gun/nozzle & its control mechanism, not the car in any way. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #55508 18th Mar 2011 10:58pm
wackyjim
You could very well be right RRVSE but as I said never had an issue with any fiiling station in the RRS Neutral
Post #55510 18th Mar 2011 11:01pm
skavitch
I had the same problem of fuelling taking forever.
I had a new filler neck fitted under warranty.
Sorted now. Mine is MY07 Audi A6 3.0 Allroad Quattro
Ducati 1200 Multistrada S
Post #55521 18th Mar 2011 11:22pm
mzplcg
That's because the RRS is ostensibly a D3, not a FFRR. Completely different fuel tank and filler neck. My D3 was never a problem but the FFRR can be a royal PITA sometimes. Depends on which garage I'm at.
Post #55526 18th Mar 2011 11:30pm
Dogman
I think sainsburys is ok (fill speed wise) & I need to take a day's leave if I'm filling up @ tesco..
Post #55537 19th Mar 2011 12:04am
I had this issue on the TDV8, there is a known Technical Bulletin about it, and I had my fuel filler neck replaced. However, I still find some pumps just click off annoyingly, so I have no choice but to turn the nozzle upside down, then it seems to work. The only downside really is that you sometimes need a glove on each hand to prevent getting diesel on you.
Censored poor really, ever filled up an FL2? they don't have the stupid misfueling guard inside the filler, just a BIG filler neck that swallows ANY diesel nozzle like a french whore gobbles c**k. Laughing
Sometimes, all these devices designed to save myself from myself...make me SO mad. TPMS is another one. Discovery 4 HSE
Post #55647 19th Mar 2011 8:15pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Hey Dogman, are you an actual 'dogman'?...... (Just your terminology) My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #55650 19th Mar 2011 8:36pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
The problem could be that you are not used to having the misfuelling device that the FFRR Tdv8 has that the D3 and RRS don't have. I don't have a problem filling at Shell or BP forecourts but do at Esso, I have also noticed that even though they don't mark them, a lot of filling stations have one or even two pumps that are higher capacity so they can handle artics and big trucks - the tank in the RR fills in about 2 minutes from one of those. Only �93 worth of fuel, you're being a miser there Jim, that's only 2/3rd's of a tank Mr. Green 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #55670 19th Mar 2011 9:52pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
I've not had a problem in my 2006 SC, have they changed the filler neck design, or does this only occur on the oil burners?
Gone - Range Rover Supercharged 2006
Post #55693 20th Mar 2011 10:35am
