Home > My Range Rover > My L322 4.2 SC
Page 2 of 7 <1234567>
That's a shame then... Pete
Post #553782 13th May 2020 8:46pm
stu1
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
bigbo wrote:
I think I spent about 4-5 elapsed hours on the job over 3 days. Its physically hard as well, leaning into the engine bay you need two hands to support your upper body, I ended up with multiple scratches and bruises on my arms as I leaned on various places to free up my hands.
If you can, deflate the suspension (IIDTool) - lowers it quite a bit and really helps (as does climbing on the engine to get at the back plugs).
And it could have been worse - if you had the BMW engine from 2002-2005, you'd have spent a day sucking oil out of the plug wells and then replacing all the gaskets Smile
Post #553783 13th May 2020 8:47pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
The arguments are building for me to get an IID! one day maybe. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #553789 13th May 2020 9:00pm
JohnGalt11
United States 2009 Range Rover Supercharged Supercharged Santorini Black
This is what the Topix sheet from my 2009 4.2 SC looks like, for your reference.
 2009 L322 SC
Post #553801 13th May 2020 9:57pm
bigbo
Thanks for that, very interesting I would love that level of detail.
Its fairly obvious that my car was built at a time of change, I have to use two different manuals, quote from 2007 to 2010 manual
"This manual covers all aspects of 2006 model year updates in order to service the vehicle effectively, and is to be used in conjunction with the existing workshop manual Part number: LRL0477."
But nothing tells you which manual to use and when! Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #553804 13th May 2020 10:07pm
JohnGalt11
It is difficult to be surprised by things like this anymore. There wasn't a "Minor Features" tab that gives more information that what you posted? 2009 L322 SC
Post #553805 13th May 2020 10:19pm
bigbo
The Tab exists but its empty Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #553807 13th May 2020 10:30pm
JohnGalt11
Looks like you got LAND ROVERED! Rolling with laughter Big Cry 2009 L322 SC
Post #553809 13th May 2020 11:00pm
dhallworth
A lot of the information for the older cars has been removed from Topix recently unfortunately. Although the build sheet might not be available, the parts departments for the dealers should be able to narrow down what was fitted to your car by chassis number still.
I thought all Supercharged cars had the locking rear diff? My old 56 plate certainly did.
Post #553850 14th May 2020 10:49am
quavey
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
I was under the impression that only MY07 cars (with the newer interior and terrain response etc) got the electronic rear diff. It was standard on the supercharged and optional on the other models although all of them show an open padlock over the rear diff on the 4x4 info screen. I proved this with a friends 4.4 tdv8 that we knew didn't have the rear locking diff, putting my MY07 SC into rock crawl mode locked the rear diff (padlock closed), on the tdv8 is remained an open padlock 2005 E60 M5
2006 L322 4.2 SC
2020 Tesla Model S Long Range
2004 L322 4.4 Vogue, 2019 NP300 Navara, 2016 NP300 Navara, 2002 L322 4.4 HSE, 2006 (MY07) L322 S/C ,2001 330Ci Sport Track Car, 2005 650i Coupe, 2001 P38 Vogue, 2003 530i Sport Touring, 1999 P38 4.6 HSE, 2002 E39 M5, 1995 300zx TT Slicktop, 1997 M3 Evo, 1992 300zx TT Targa, 1998 323i Coupe
Post #553916 14th May 2020 8:41pm
bigbo
That fits with what I have found out so far, terrain response was first fitted late 2006 (I read somewhere that it was September I think) mine was built in February.
Also the 4x4 screen does not show the padlock you talk about, however that may only be on terrain response vehicles.
I have to get under it soon so that will be the proof for my car. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #553917 14th May 2020 8:57pm
quavey
I would say that is likely the case. The MY07 update was quite a big upgrade to be honest, I personally much prefer that later interior to what I have in my 54 4.4 V8 at the moment... I think I'm going to treat my self to something a bit newer once this debacle is over! 2005 E60 M5
2006 L322 4.2 SC
Post #553953 15th May 2020 12:50pm
bigbo
Fixed the engine cover mounting studs, drilled out the broken stud, and helicoiled the intercooler to fit the new stud from Duckworth. I used threadlock to help ensure the studs would not come out next time I removed the engine cover but also to protect them from steel to ali corrosion and added a tiny drop of copperease to the nuts. I had to superglue washers to the top of the front studs as the "top hat" washers were missing.
Whilst the plenum chamber was out I stripped that down to clean the interior, there was a lot of rubbish in there. Fitted new cabin/pollen filter and reinstalled the chamber.
So a couple of easy jobs today, next is the Diffs and transfer box...….. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #554134 16th May 2020 11:00pm
JohnGalt11
Regarding your writeup for the plug change, I changed them on my 2009 4.2 and found it quite easy. Some methods that might be helpful if there is a next time.
1. Start with the right tools. 3/8 inch ratchet with a proper spark plug socket, a short 3-4 inch extension a longer 8 inch extension, and a swivel were all I needed to get all the plugs out and back in easily. Attach the swivel to the socket and then add extensions as necessary and you shouldn't have any problem getting into or out.
2. I left all the coil packs plugged into their wires and had enough room to get them out of the way working one cylinder at a time. This way I didn't have to worry about breaking a clip or getting other tools in there to pry them off or on. The one on the back left was the most difficult to deal with as OP mentioned but it wasn't bad. I didn't have to loosen or remove the brake valve. If the others took 5 min each, that one took 8 min.
3. Make sure your engine is cold when you do this job. Makes getting the plugs in and out much easier and and they get tightened properly too.
4. Use a little silicon spray on the threads of the new plugs. Or just spit on them a little, and they will thread on much easier.
Start to finish, I think I spent 1.5 hours at an easy pace for all 8 plugs, and I'm by no means an expert or experienced mechanic. 2009 L322 SC
Post #554146 17th May 2020 7:09am
bigbo
I think the 2009 model must be very different, perhaps from MY2007 because the left bank no 4 a straight 150mm extension would not fit, I had to use a wobble extension just to get that extra degree or to of movement and it was fiddly because of a mixture of wiring harness, coolant and air con piping was in the way. The right bank number 1 plug was inaccessible without moving either the oil breather or the device in this picture (now known to be the brake vacuum pump)
I think this is due to the 2006 model being a bit of a one off during the change from BMW to Jag, I can almost imagine the engineers saying let just bung the AJV8 in whilst we work out how to do it properly!
Maybe there are other 2006 SC owners who can add their comments. Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #554228 17th May 2020 6:03pm
