Home > My Range Rover > My L322 4.2 SC |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8230 |
That's a shame then... Pete
13th May 2020 8:46pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 583 |
The arguments are building for me to get an IID! one day maybe. Range Rover 4.2 Supercharged 2006
13th May 2020 9:00pm |
JohnGalt11 Member Since: 31 Mar 2020 Location: Iowa Posts: 27 |
This is what the Topix sheet from my 2009 4.2 SC looks like, for your reference.
13th May 2020 9:57pm |
Thanks for that, very interesting I would love that level of detail.
13th May 2020 10:07pm |
It is difficult to be surprised by things like this anymore. There wasn't a "Minor Features" tab that gives more information that what you posted? 2009 L322 SC |
13th May 2020 10:19pm |
The Tab exists but its empty Range Rover 4.2 Supercharged 2006
13th May 2020 10:30pm |
Looks like you got LAND ROVERED! 2009 L322 SC |
13th May 2020 11:00pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3097 |
A lot of the information for the older cars has been removed from Topix recently unfortunately. Although the build sheet might not be available, the parts departments for the dealers should be able to narrow down what was fitted to your car by chassis number still.
14th May 2020 10:49am |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 302 |
I was under the impression that only MY07 cars (with the newer interior and terrain response etc) got the electronic rear diff. It was standard on the supercharged and optional on the other models although all of them show an open padlock over the rear diff on the 4x4 info screen. I proved this with a friends 4.4 tdv8 that we knew didn't have the rear locking diff, putting my MY07 SC into rock crawl mode locked the rear diff (padlock closed), on the tdv8 is remained an open padlock 2005 E60 M5
14th May 2020 8:41pm |
That fits with what I have found out so far, terrain response was first fitted late 2006 (I read somewhere that it was September I think) mine was built in February.
14th May 2020 8:57pm |
I would say that is likely the case. The MY07 update was quite a big upgrade to be honest, I personally much prefer that later interior to what I have in my 54 4.4 V8 at the moment... I think I'm going to treat my self to something a bit newer once this debacle is over! 2005 E60 M5
15th May 2020 12:50pm |
Fixed the engine cover mounting studs, drilled out the broken stud, and helicoiled the intercooler to fit the new stud from Duckworth. I used threadlock to help ensure the studs would not come out next time I removed the engine cover but also to protect them from steel to ali corrosion and added a tiny drop of copperease to the nuts. I had to superglue washers to the top of the front studs as the "top hat" washers were missing.
16th May 2020 11:00pm |
Regarding your writeup for the plug change, I changed them on my 2009 4.2 and found it quite easy. Some methods that might be helpful if there is a next time.
17th May 2020 7:09am |
I think the 2009 model must be very different, perhaps from MY2007 because the left bank no 4 a straight 150mm extension would not fit, I had to use a wobble extension just to get that extra degree or to of movement and it was fiddly because of a mixture of wiring harness, coolant and air con piping was in the way. The right bank number 1 plug was inaccessible without moving either the oil breather or the device in this picture (now known to be the brake vacuum pump)
17th May 2020 6:03pm |
