![]() | Home > Technical (L322) > Should I use Lucas additive when changing oil on the GM5L40E |
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 ![]() ![]() ![]() |
Good evening
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
The manufactures of the gearbox and the car maker don't use or recommend any additives....
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 982 ![]() ![]() |
As Pete says, put in whatever you feel happy with. Dexron is fairly straight-forward stuff, and the only downside of going from Dexron III to VI is the lower viscosity – especially if your transmission is getting worn and the clearances are high.
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 870 ![]() ![]() ![]() |
thanks Mazza, I'm going to get some from MVATF PLUS from Dunmow Motor Factors tomorrow
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Hi
Your petrol Rangie has a different gearbox and uses different oil to the OP's diesel one...!! Pete I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
I did a lot of reading on the comma web site about their oils, how many times the company has changed hands etc, their own oil blending plant, going since 1965 etc etc https://www.commaoil.com/about/history Was happy about the research so decided to switch from my usual Castrol to this brand. (also much cheaper on the account) I think due to these gearboxes being right on their limit on the range rovers they were dumped into, I think i'll use the stop slip, not the whole bottle. I'll ring the specialist again to find out how much they put in, they may only put 6 or 12oz or so and not the full 24oz bottle. |
yikes, thx Peter
Yep, just use the correct straw coloured oil... |
£90 !! - thats a lot of money on oil.
indeed mazza, good find - only £53 delivered for 10 litres - happy days
Why do people never listen...
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 752 ![]() ![]() |
+1 for Haylands reply, how anyone can justify using the wrong lubricants just to try and save next to nowt is beyond me.
Its not just what they write at the side of an oil can, If the gearbox specialists who rebuild the GM5 and the ZF5 only all day every day say that they use the same stuff that I purchased then I think they know what there talking about as well ??
