Home > My Range Rover > My Remapped 2002 Range Rover Vogue 4.4 V8 |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8283 |
I deleted the rear silencer to aid departure angle whilst offroading, I did it just to see what it was like as no one had done it before, on my Classic fatty, removing the rear box gave a nice note as well as a lovely tick over burble...
5th May 2020 8:57am |
green-oval-nut Member Since: 02 Sep 2016 Location: Tunbridge Wells, Kent Posts: 929 |
Trust me, that video gave me the full impression, the speakers on my laptop were making my table vibrate If this had been my P38 Range Dog that I used to have, then I would have been jumping up and down with joy for the full delete, but I have heard the exhaust system with the sports silencers, They do give a nice burble which is what I want. I will most definitely be doing a before video and after video, plus photo's of the install.
5th May 2020 11:08am |
You are getting addicted to cars... take more cold showers.... Pete
5th May 2020 11:53am |
I was born addicted
5th May 2020 12:01pm |
I finally got around to trial fitting my universal nudge bar, didn’t like the look with the lights so close, have moved them apart more, but I think this will end up on my ML
6th May 2020 6:34pm |
Sorry to be negative but to me that looks like it came off a mobility scooter, don't think that will add anything to a fatty or an ML..!!
6th May 2020 7:11pm |
I think the way it was mounted doesn't do it justice. As it sits in the pictures is much further forwards than it will actually sit once properly mounted. I am pretty sure I am going to fit it to my ML, but that is going to take some extra engineering as the bumper is no where near as flat as the Range Rover. I have found another spotlight mounting bracket which is basically the same, but without the bar on the front so in theory, would be barely visible.
7th May 2020 11:35pm |
I really shouldn't have been surprised, yet I was, The airflow meter is dead The reason I was surprised when I shouldn't have been, was when I first got the car and a certain rip off garage who had me over for thousands on 3 cars in one year, charged me for a brand new genuine airflow meter. THAT airflow meter as I discovered today was not in fact replaced. I was scrubbed with a wire brush in the housing and I guess spray cleaned. So now, I actually need a new airflow meter. So I am surprised that I am surprised at this revelation. Only good news out of this is, I don't think that there was any other work that they were paid to do left on the list. So in theory, I am passed the dodgy work now.
18th May 2020 9:10pm |
My new exhaust turned up, All I can say is, I am glad I upgraded to the set with silencers Sounds awesome. I love them. Took me about 2 hours to fit. (Ignore the place I used the jack ).
19th May 2020 8:51pm |
Still love the new exhausts But the noise pointed out a blatent misfire. After running live data, found that coil packs 1 and 8 were giving feedback, Showing more volts than the others when running, I swapped them out and the misfire vamoosed. But the voltage readings remained the same, checked the earth cables and the looms and can't see anything wrong. And it seems slightly underpowered on acceleration at the moment, but not sure if that is because the MAF is disconnected. After the 9 mile test drive, parked Oscar up and put all the coil covers back on as I had dangerous electrics to deal with in the campervan.
25th May 2020 8:16pm |
Starting to make progress now. The symptoms I had were, poor idling, stalling, really rough gear changes, high emissions smell. So after running diagnostics, I fitted a replacement airflow meter including the clips that were missing. Plugged it in. Idles properly, gear changes are super smooth, engine sounds nicer, the exhaust sounds even better no longer stalls, accelerates amazingly quick again. A real joy to drive. BUT I still need to sort the starter motor out and the alternator. The alternator is working, it's just noisy, and it is 30/70 if it is going to start, although learnt a little trick for the good weather days, If the starter doesn't engage, just rock the car a little so it bounces when in park, that seems to allow the starter motor to work. But this also presents a problem for fueling up, I cannot risk stopping at a petrol station for fear or it not starting, so now have a 20 litre jerry can, and fill up at home before I go out And the only reason I have not got the money to sort these 2 jobs out at the moment, is because I am pouring every spare penny I can find into ML number 2, and ML number 1 is still at the garage awaiting another repair |
13th Jun 2020 9:03pm |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 901 |
We will need a video of the new exhaust pipes at idle and driving g iv the same pipes on my nay watch list. Trou let is when I did a centre delete on my p38 it was horrible on the motorway I dont want to ruin my l322 |
13th Jun 2020 9:44pm |
I don’t know how to put videos on here. But you can’t hear them at motorway speeds from the cabin barely. I wouldn’t take out any other section of my exhaust for noise though or it would become a problem 😂. |
13th Jun 2020 9:52pm |
Well your just down the road from me I mite have to pop round for a listen |
13th Jun 2020 9:56pm |
