Home > In Car Electronics (L322) > Dead Range Rover |
bruce Member Since: 21 Jun 2009 Location: Cumbria Lake district Posts: 90 |
Has anybody encountered the Parking aid control module issue? Frightening that everything is dead, hard reset doesn’t work and all because of damp in the parking module case. I cannot see wher water has got in, everything else is fine. If you are not part of the solution you are part of the problem!! |
27th Apr 2020 5:06pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
What 'Parking aid control module issue'? |
27th Apr 2020 6:08pm |
The parking aid control module located in the rear is prone to water ingress, From where I don’t know but if water gets in to this little black box the vehicle is dead. Nothing, rein, nowt, all, Trying to start it all you get is smart key not found.. I found a fantastic little video that showed the issue and made my day because I would never have found the problem. If you are not part of the solution you are part of the problem!! |
27th Apr 2020 7:58pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Bruce
28th Apr 2020 12:30pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Does the car start if you unplug the PAM ? .
28th Apr 2020 2:40pm |
Yes I’ve seen the bulletin but no sign of damp anywhere else. The inside of the module is horrible, look. Once disconnected everything works fine, whilst connected everything is dead.
28th Apr 2020 5:18pm |
Could be clamping one of the busses |
28th Apr 2020 7:36pm |
You could always give it a good scrub with a toothbrush and some contact cleaner, might just get it back working (it did for my Sat Nav DVD unit - which looked just as bad) - although those capacitors don't look happy. You have nothing to lose by trying it. .
28th Apr 2020 8:33pm |
I have got a new one for£80. Not worth damaging the wife’s tooth brush. If you are not part of the solution you are part of the problem!! |
29th Apr 2020 6:53am |
Now put a plastic cover over that . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
29th Apr 2020 8:23am |
