![]() | Home > In Car Electronics (L322) > Dead Range Rover |
bruce Member Since: 21 Jun 2009 Location: Cumbria Lake district Posts: 90 ![]() ![]() ![]() |
Has anybody encountered the Parking aid control module issue? Frightening that everything is dead, hard reset doesn’t work and all because of damp in the parking module case. I cannot see wher water has got in, everything else is fine. If you are not part of the solution you are part of the problem!! |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 ![]() ![]() ![]() |
What 'Parking aid control module issue'? |
The parking aid control module located in the rear is prone to water ingress, From where I don’t know but if water gets in to this little black box the vehicle is dead. Nothing, rein, nowt, |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
Bruce
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Does the car start if you unplug the PAM ? .
Yes I’ve seen the bulletin but no sign of damp anywhere else. The inside of the module is horrible, look. Once disconnected everything works fine, whilst connected everything is dead.
Could be clamping one of the busses |
You could always give it a good scrub with a toothbrush and some contact cleaner, might just get it back working (it did for my Sat Nav DVD unit - which looked just as bad) - although those capacitors don't look happy. You have nothing to lose by trying it. .
I have got a new one for£80. Not worth damaging the wife’s tooth brush. If you are not part of the solution you are part of the problem!! |
Now put a plastic cover over that ![]() Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember ![]() Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
