Home > Maintenance & Mods (L322) > Front mudflaps drilling?
jackie-o
Netherlands
Hi,
Does anyone know if fitting front mudflaps on a 2011 RR Vogue requires drilling?
I cant find the fitting instructions anywhere online. I know the rears need drilling but again, cant find anything on the fronts.
They changed the mudflaps after 2006 so anyone with a later car, would be great to get feedback.
Should also specify that this concerns mudflaps CAS500060PMA for car without exterior design pack.
Thanks! RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #551078 20th Apr 2020 10:12am
RRYorks
United Kingdom 2010 Range Rover Vogue TDV8 Barolo Black
Sent PM
Post #551094 20th Apr 2020 11:51am
Fox889
I'm going to say yes. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
BMW R1200GS
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #551101 20th Apr 2020 12:53pm
jackie-o
Netherlands
Fox889 you would be correct. RRYorks was kind enough to send me a pdf.
Thanks both!
J RR Vogue 4.4 TDV8 - 11
Post #551108 20th Apr 2020 1:08pm
Anvil
Could I trouble you for a copy of that too? Please?
Thanks in advance!
Si.
Post #551381 22nd Apr 2020 11:56am
this is from our wiki,
https://www.fullfatrr.com/forum/topic18936.html ... - .- -.
Post #551383 22nd Apr 2020 12:01pm
Anvil
Thanks Stan. I did it again.... made an assumption that as there was a PDF that it wouldn't be in the Wiki..... 3 strike rule? Embarassed
Post #551394 22nd Apr 2020 1:24pm
The simple answer is YES & NO! If a dealer fits them then yes they will drill the bodywork BUT! You don't need to drill the bodywork! The holes in the sides are for them that seriously use their RR's off road! The side bolts simply help you NOT to rip the things off!
They can be fitted using double sided tape on the sides instead of the outer bolts! This way you DONT have holes drilled into your pride and joy! There are bolts and clips down the inside edge of the flaps that more than hold them on securely for "normal" use!
Also helps when selling the car on... If the buyer like me, hates mudflaps! Thumbs Up
Post #551437 22nd Apr 2020 11:49pm
jackie-o
Netherlands
@ CTC; thanks! Since mine are already fitted by a previous owner I´m going to guess they were drilled. Will have a look once car is back from garage.
The reason for my question is that I now want to fit the fixed sidesteps with integrated mudflaps and want to know if the these will cover, or even better, use the same holes as the ones that are there now....
@Anvil & Stan; the Guide in the wiki is for older cars. I have the pdf that RRYorks was kind to send, can I upload it somewhere and you could add it to the wiki? RR Vogue 4.4 TDV8 - 11
Post #551457 23rd Apr 2020 9:13am
Anvil
Mine's an 06, so the wiki suits thanks J-O. I had some delivered the other day and I've fitted them, but they came with BMW 7-series fitting instructions for some reason..... Just wanted to make sure I did it correctly. -Turns out I did!
Si.
Post #551461 23rd Apr 2020 9:55am
Jackie, yes they all fit in the same holes sir 👍
Post #551513 23rd Apr 2020 6:33pm
