Home > Maintenance & Mods (L322) > Front mudflaps drilling? |
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 37 |
Sent PM |
20th Apr 2020 11:51am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
I'm going to say yes. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
20th Apr 2020 12:53pm |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
Fox889 you would be correct. RRYorks was kind enough to send me a pdf.
20th Apr 2020 1:08pm |
Anvil Member Since: 18 Jan 2019 Location: Dorset Posts: 140 |
Could I trouble you for a copy of that too? Please?
22nd Apr 2020 11:56am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
this is from our wiki,
22nd Apr 2020 12:01pm |
Thanks Stan. I did it again.... made an assumption that as there was a PDF that it wouldn't be in the Wiki..... 3 strike rule? |
22nd Apr 2020 1:24pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
The simple answer is YES & NO! If a dealer fits them then yes they will drill the bodywork BUT! You don't need to drill the bodywork! The holes in the sides are for them that seriously use their RR's off road! The side bolts simply help you NOT to rip the things off!
22nd Apr 2020 11:49pm |
@ CTC; thanks! Since mine are already fitted by a previous owner I´m going to guess they were drilled. Will have a look once car is back from garage.
23rd Apr 2020 9:13am |
Mine's an 06, so the wiki suits thanks J-O. I had some delivered the other day and I've fitted them, but they came with BMW 7-series fitting instructions for some reason..... Just wanted to make sure I did it correctly. -Turns out I did!
23rd Apr 2020 9:55am |
Jackie, yes they all fit in the same holes sir 👍 |
23rd Apr 2020 6:33pm |
