Home > Maintenance & Mods (L322) > Pre Oil Leak fix advice |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
There are several threads on here that'll take you through the process, there's a certain pipe that has an offshoot pipe that is easily broken & is expensive to replace, but, just look back & there's loads of advice for you.
21st Apr 2020 5:38pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
The little pipe is No3a in the link. Also look out for the connection at 3 as it can be difficult to remove of you haven't got a plier which is mad efor the job.
21st Apr 2020 6:32pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4302 |
Make sure the 4 doughnut hoses are the updated thicker ones. These are the updated ones. Much thicker side walls than original ones. Original ones are thin as
21st Apr 2020 6:49pm |
QuebecTango Member Since: 06 Jan 2019 Location: Brighton Posts: 55 |
Have recently done mine, it looks worse than it is. No 3 in the link the plastic fitting that clips into the bracket “crumbled” when I removed it & that bit only comes with the thermostat housing & associated pipes, anticipated 150 quid but turned out to be around £40 - inconvenient though also, as well documented, the piece going into top hose is delicate! Did the cooler gaskets not expensive & not difficult once your in there. Instructions in wiki just the job
22nd Apr 2020 4:39am |
Ragingrover Member Since: 05 Oct 2019 Location: Malvern Posts: 152 |
Thanks all !! I did find lots of useful info on Wiki, if only I'd seen it when I searched first, so sorry for asking you to repeat yourselves.
22nd Apr 2020 8:27am |
I'm not sure of the name of the bit at 3a, but top hose comes to mind and if you speak to Advanced Factors Paul he'll soon set you right, (as I hope Duckworths would if you phone or email. Seems no point using the link on here as others have found).
22nd Apr 2020 10:03am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2471 |
Be very conscious that the open oil orifices exposed when the oil cooler is removed supply unfiltered oil to the rest of the engine, either directly or via the oil cooler and any contamination could result in a replacement engine being sought. Cleanliness is critical. |
22nd Apr 2020 10:26am |
I got my Viton seals for the rear pipe today so that jobs for tomorrow. Whilst I'm up close in the engine bay I'll see if that oil cooler is a current problem. Given it seems I'm likely to need additional parts before I tackle the oil cooler, I'll leave it till I'm confident I've got everything to hand. This car is my daily driver (well it was given the current situation!) |
22nd Apr 2020 1:18pm |
R
22nd Apr 2020 1:20pm |
ebay, try this link:
22nd Apr 2020 3:16pm |
Thanks R
23rd Apr 2020 3:38pm |
Just done the two O Rings and yes its an easy but slighty awkward job, if that makes sense ? My only additional piece of advice is.... when trying to refit the insert into the casting i.e. "push it back in" with the new seals, do your best to keep the insert square onto the casting. Because the only puchase or grip you have is on a shaped and bent pipe its very easy to push at an "off" angle. Initially I got a bit worried I wasn't going to get it to fit but then pushing the pipe away from yourself at the same time pushing into the casting and "POP" it goes quite easily !
24th Apr 2020 1:05pm |
