![]() | Home > Technical (L322) > 2 sump plugs - 3.6 TDV8 |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 ![]() ![]() ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Do both. Same sump, but the oil return ends up by the 2nd plug which is normally overlooked. ends up caking up and you lose oil return from the turbos. Which is bad.
John-suusex Member Since: 31 Oct 2019 Location: Sussex Posts: 53 ![]() ![]() |
one thing, be ready, not a lot of room and it drains straight onto the subframe....unless someone had drilled a hole through.. 2008 TDv8 Vogue in Java black x2
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
I put a hole in my L322’s subframe mainly so I could get a socket to the sump plug. ______________________________
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
I just used to use a old cut up bottle to funnel it past the subframe |
