Home > Technical (L322) > 2 sump plugs - 3.6 TDV8 |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 |
2nd Aug 2016 9:44pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8488 |
Do both. Same sump, but the oil return ends up by the 2nd plug which is normally overlooked. ends up caking up and you lose oil return from the turbos. Which is bad.
2nd Aug 2016 10:16pm |
John-suusex Member Since: 31 Oct 2019 Location: Sussex Posts: 42 |
one thing, be ready, not a lot of room and it drains straight onto the subframe....unless someone had drilled a hole through.. 2008 TDv8 Vogue in Java black x2
20th Apr 2020 5:52pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I put a hole in my L322’s subframe mainly so I could get a socket to the sump plug. ______________________________
20th Apr 2020 10:49pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
I just used to use a old cut up bottle to funnel it past the subframe Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
21st Apr 2020 8:21pm |
