Home > Technical (L322) > 2 sump plugs - 3.6 TDV8
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
I am on the train on the way back from London and just having a mooch about the site.
My 3.6 TDV8 07 is in at the moment getting a new alternator, I have asked that the turbo pipes get changed whilst it is stripped down, and an oil change - might aswell whilst it is in the garage.
It seems from various threads that there might be a second drain (sump) plug, something to do with the turbo, rather than just the obvious oil drain plug, is that right ??
If so where is it and what does it drain that the main drain doesn't ?
Ta muchly 2011 Range Rover Vogue SE
Post #398871 2nd Aug 2016 6:36pm
SveinHa
Norway 2008 Range Rover Vogue TDV8 Buckingham Blue
Not sure how things look like inside the sump but as long as there are two, it seems wise to drain both. "Plentraktoren/Garden tractor": 2008 L322 TDV8
"Project": 1990 90 County 300tdi
Post #398905 2nd Aug 2016 9:44pm
Do both. Same sump, but the oil return ends up by the 2nd plug which is normally overlooked. ends up caking up and you lose oil return from the turbos. Which is bad.
Open both and let them fully drain. If you have no proof it has been done then do a short service cycle and change the oil again in a couple of 1000 miles using the same method. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #398912 2nd Aug 2016 10:16pm
John-suusex
one thing, be ready, not a lot of room and it drains straight onto the subframe....unless someone had drilled a hole through.. 2008 TDv8 Vogue in Java black x2
2000 P38 They aren't all bad!
1996 D1 3.9 es
1996 Volvo 850 GLT
Post #551138 20th Apr 2020 5:52pm
rar110
I put a hole in my L322’s subframe mainly so I could get a socket to the sump plug. ______________________________
Post #551186 20th Apr 2020 10:49pm
TJH1985
I just used to use a old cut up bottle to funnel it past the subframe Thumbs Up Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
Previously George a 2007 MY07 Java Black VSE 3.6 TDV8
Previously a 04 MY04 Defender 90 Sad
Post #551307 21st Apr 2020 8:21pm
