Home > Maintenance & Mods (L322) > 3.6 TDv8 / ZF6HP26 Gearbox Oil Change |
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 |
I bought 7L of genuine Lifeguard 6 from a bay retailer in Germany about £13/L
20th Apr 2020 7:06pm |
paulbrown22 Member Since: 23 Dec 2017 Location: London/Poole Posts: 352 |
When I had my 5.0 S/C done, the guys at the local LR independent I've used for years, Brownchurch, said they put Ravenol in pretty much all the vehicles they do, as most customers prefer the reduced cost of it. But I did explicitly ask them to use ZF for mine, which they also had in stock, on the basis I'd rather know it's the exact manufacturer fluid as I'm not expecting to change it again for quite a while! But if they are happy to use it on customer vehicles, I do trust them completely, and they said they'd never had any issues with it so far.
20th Apr 2020 7:50pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Some anecdotal evidence, I replaces my gearbox oil with Ravenol last year, gear box was instantly smoother and function better, stopped slight surging at low rev’s.
21st Apr 2020 7:26am |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 |
Can dr.tranny additive do some harm to my 6hp26 transmision if I add it as a precaution?
21st Apr 2020 9:20am |
I am not convinced on additive, the main manufacturers would add or sell this ‘snake oil’ (my opinion) if there was benefits other than just a revenue stream.
21st Apr 2020 9:30am |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
What’s this shudder fix? Is it need? Also I don’t have any leaks on my gb so do i need to do the sleeve fix? Current stable:
21st Apr 2020 9:06pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 980 |
If your torque converter LUC engagements or gearshifts are improved by adding a friction modifier (assuming you’re using the correct fluid) then there is a problem with the friction elements in your transmission. Adding the stuff doesn’t put friction material back on the plates, it temporarily masks their worn condition.
21st Apr 2020 11:14pm |
Thanks Phil
22nd Apr 2020 7:34am |
I guess the sleeve replacement is worthwhile if you already have the sump pan/filter off (as you have easy access to the release mechanism) but, if there’s no sign of a leak, I wouldn’t bother doing it especially.
23rd Apr 2020 11:21am |
Thanks Phil
23rd Apr 2020 1:09pm |
I’d strongly recommend that you DON’T reset the solenoid adaptions unless you’ve either seen the existing adaptions or have replaced the solenoids/Mechatronic or updated the software.
23rd Apr 2020 2:19pm |
Ok Phil,
23rd Apr 2020 2:35pm |
Our friends on the BMW X5 forums seem to have no problems getting their diagnostic kit to display the adaption values for their solenoids before resetting them. The values (offsets for both clutch fill pressures and rapid fill times) can then be compared to the controller’s setting limits to determine if any of the solenoids are running at their extremes and are therefore faulty. It’s a great shame if the diagnostic tools available for the L322 aren’t capable of doing this, too. Is it worth some further investigation, or are you pretty sure that your kit won’t display this information?
23rd Apr 2020 4:02pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1782 |
I'm sure I've seen the adaption readings within the IID Tool |
23rd Apr 2020 4:44pm |
