Home > Maintenance & Mods (L322) > DPF full 4.4 TDV8 2012 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
Do a search on here but intake leaks is where you should start before driving it again. Check the 4 doughnut hoses under the engine cover first, check intercooler hoses, check intake manifold for leaks. Ideally a smoke test machine is needed to help find it. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
18th Apr 2020 3:45pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35384 |
it can take up to 20 mins drive...basically you need to run it until its hot enough to burn off the soot ....surely there must be a pharmacy 20 mins away.. ... - .- -.
18th Apr 2020 4:32pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8638 |
20 min blast up an autoroute of your choice. depends how strict the local gendarmerie are though I suppose. If they are likely to take you behind the small Peugeot van and give you a good flogging then maybe not..... There is nothing that can't be fixed with a hammer😜😜
18th Apr 2020 4:50pm |
SFM Member Since: 19 Feb 2012 Location: dordogne Posts: 258 |
Any idea why it was smoking so much before the warning came on?
19th Apr 2020 5:23am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1776 |
6 miles is nowhere near enough a clear out the DPF |
19th Apr 2020 6:23am |
I appreciate that mikey
19th Apr 2020 7:45am |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
This sounds a bit similar to what I have experienced with my own 2011 4.4 TDV8. I had some air intake leaks that were fixed by my local Indy, however just before lockdown the sudden plume of smoke came back and my DPF threw the amber followed by red warnings. I managed to clear the red and carried out a regent but haven’t been able to go any further due to the current restrictions. I’m hoping that once these are lifted I can carry out some more testing so will be interested to hear if you find anything in the meantime. You can read my latest issue in the link below.
19th Apr 2020 1:23pm |
Hi again
20th Apr 2020 8:13am |
Anyone? |
20th Apr 2020 1:48pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3168 |
several members have posted their versions of replacement pipes. do a search and you will see several options
20th Apr 2020 1:51pm |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 |
partsnumber is 4 x LR056285 RR Vogue 4.4 TDV8 - 11
20th Apr 2020 4:58pm |
GGX Member Since: 31 Jul 2013 Location: North Wales Posts: 61 |
I cleared by putting in sport mode and drive at 55mph for 20min on a duel carriage way, sport holding the gear down to it revs more generating more heat. |
28th Apr 2020 3:16pm |
Just an update
11th May 2020 12:52pm |
1. Do you have an IID tool or OBC reader? Your soot reading should be less than 28g as above that it cannot be force regenned by a dealer. It will have to be cleaned.
11th May 2020 1:21pm |
