Home > Maintenance & Mods (L322) > DPF full 4.4 TDV8 2012
Page 6 of 6 <123456
SFM
France 2012 Range Rover Vogue TDV8 Rimini Red
Right... just got a quote from Duckworth, new fitting is £116.59 +Vat
So not the end of the world.
Still monitoring, now up to 17.6g a regen is imminent!
Let’s see what happens
Post #556505 4th Jun 2020 2:13pm
DrRob
What do you get for your £116? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #556521 4th Jun 2020 4:50pm
SFM
Dr Rob
As Far as
I’m Aware a new plastic fitting including the clip
Not 100% sure
Steve
Post #556532 4th Jun 2020 5:57pm
SFM
Right...
So yesterday I was at 17.5g, so decided to take it for a run, now where I live, it’s almost impossible to find a road that I can sit at 50mph for any length of time. Nearest motorway is 80mile round trip.
So I drove on “B”roads trying to keep between 40-50mph, not easy!
The level kept rising, until it hit 20.5g, by this stage I’m thinking that the light is going to come on again.
But then, the exhaust temperature started to rise, and we started a regen😁
Slowly the level started to drop, but I knew that I was running out of road, turned car around, and started the return journey.
Interestingly, speed doesn’t seem to make a difference on the regen, as I had to come back through a couple of small villages, at less than 30mph, and it was still in burn mode and levels continued to drop, drove for another half hour, level was down to 3.26g, and exhaust temps dropped, burn complete. By the time I got home, probably about 17miles after the burn, level was at 5.1g. Do you think that this is normal?
I have noticed that at a steady constant speed, it rises very slowly, but when you are accelerating, decelerating, climbing hills, or going slow through towns etc. It really is quite a rapid rise in level
As mentioned in my previous posts, apart from the amber light,I have had no fault codes relating to this, car has not gone into limp mode, and drives lovely. For the last 300+ miles it’s averaged 28.5 mpg even on these roads.
Oil dilution is reading about 6 now seems to go up 1 point for each regen (it was on over 4 when I got it back from garage)
Any thoughts?
Steve
Post #556629 6th Jun 2020 6:40am
GGDR
Hi Steve, have a read of my 'what to do if your DPF is blocked' post
It covers a lot lot of DPF 101 so have a read. It doesn't cover Oil Dilution much though.
And best advice there is frequent - e.g. 5000mile - oil changes.
I, like many 4.4TDV8 owners use Shell Helix AF-L
Like you I am penned in without easy access to a 50mph stretch of road so I monitor my soot.
Good news your regeneration worked as it should. Thumbs Up
. Cheers, Greg
Post #556630 6th Jun 2020 7:37am
GGDR
Oh and yes a regeneration finishing at around 5g is perfectly fine.
. Cheers, Greg
Post #556631 6th Jun 2020 7:38am
SFM
Hi Greg
But do you think that a rise of 2g in 17miles on B roads is normal?
Steve
Post #556632 6th Jun 2020 7:44am
GGDR
Simply: Yes.
The thing is the grams value is a calculated value based on inputs from various factors, throttle, revs, pressure difference in the DPF and loads more.
Don't get too fixated, but with an IID tool monitor it and manage it.
. Cheers, Greg
Post #556635 6th Jun 2020 8:21am
Baltic Blue
Steve,
It’s not out of the normal to get random “stepped” increases of 2-3 g when you least expect them.
I don’t think you have got any need to worry.
Just join the DPF “management “ club.
You know when the levels are nearing the need for a burn and by careful monitoring you can prevent any further alarms.
Mike.
PS. I 100% agree with Greg regarding 5k miles max between oil changes. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #556636 6th Jun 2020 8:24am
dont you mean 'join the sooty club' Mike,
Mr. Green Wink ... - .- -.
Post #556637 6th Jun 2020 8:35am
Baltic Blue
Rolling with laughter
We can’t all afford posh new L405’s Big Cry
Post #556639 6th Jun 2020 8:46am
SFM
Cheers mike/Greg
You have put my mind at rest, a bit now.
I am getting obsessed with it now!
Having never monitored it before the warning, I have no idea as to what is normal.
Is there a way of saving the selection of live values on the iid tool
So as you don’t have to scroll through and select them each time?
Steve
Post #556644 6th Jun 2020 9:23am
Baltic Blue
Create a favourites list.
Details in handbook, which is in the Wiki.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #556646 6th Jun 2020 9:39am
SFM
Thanks mike!👍👍
That’s going to save a lot of time before we go anywhere😄😄
Post #556649 6th Jun 2020 10:22am
Range Rover L322
SFM wrote:
Right...
Any thoughts?
Steve
All sounds completely normal.
Post #556819 7th Jun 2020 5:23pm
Page 6 of 6 <123456
