Home > Technical (L405) > Upgrade speakers |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3783 |
I’ve got the standard set up for an AB I.e. an 825W system. I see powerful are selling speaker upgrades for this but at £250/set they really do need to make a difference. Has anybody done this upgrade and is it an immediately obvious difference.? Geoff |
17th Apr 2020 11:56am |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 771 |
This is discussed at length here:
17th Apr 2020 5:18pm |
Sounds about right, it's only the 4 woofers in the doors. |
17th Apr 2020 6:08pm |
It would be interesting to find out if the Signature System subwoofer, which now is in the back, is different from the one in the Surround System in the 2018+ models. I'm wondering what was the point of moving it so now it fires towards the bumper?
17th Apr 2020 6:24pm |
https://www.powerfuluk.com/range-rover-l40...f-267.html Geoff |
17th Apr 2020 6:50pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
I guess that if you feel like you're lacking bass, then worth a punt..... |
18th Apr 2020 6:28am |
Felstmiester Member Since: 06 Apr 2019 Location: Hertfordshire Posts: 262 |
The 825w surround meridian system runs exactly the same door speaker set up as the lesser 380w system. Everything I’ve read where people have fitted the 4ohm speakers from the 1700w system ( picture above) have noticed considerable improvement. Even more so if you soundproof the doors |
20th Apr 2020 5:16pm |
Jase71 Member Since: 13 Apr 2016 Location: Portsmouth Posts: 479 |
Interesting...I have the base 380W speakers but it says on the Powerful website that the amplifier has to be upgraded to go up to the premium speakers. Does anyone know how you upgrade the amplifier? 2017 Range Rover Vogue V6 Diesel
21st Apr 2020 9:09am |
ilard Member Since: 21 Oct 2012 Location: London Posts: 708 |
Before I specced the 1700w system I asked Meridian a few questions which was an extremely tedious process to go through. I got the destiny impression that this in-car lark was not their main money-spinner. And whether or not their response makes any sense is another matter!
L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
21st Apr 2020 11:49am |
Sorry I meant upgrading from 380 to 825W 2017 Range Rover Vogue V6 Diesel
21st Apr 2020 12:29pm |
If it is the same amplifier as in the Range Rover Sport (and it probably is), this should apply:
21st Apr 2020 7:10pm |
The 825w amp is plug & play. The 1700w is not. And although the 825w will drive all your speakers that your 380w amp did but much better ( even if you upgrade woofers ) if you install the extra centre dash speaker and rear shelf speakers it won’t power those up until you edit the ccf. Also I don’t think the meridian amps are compatible with the HK system. You have to find an upgraded HK amp. |
22nd Apr 2020 7:13am |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 461 |
Hello
6th Jul 2020 4:05pm |
notanrdx Member Since: 23 Jun 2020 Location: Austin Texas Posts: 37 |
I have a 2017 and I just completed the speaker upgrade from the L3 (base level) to the speakers that come with the 1700W super premium system. I purchased the woofers from powerfuluk and the tweeters and mids from an internet dealer. Here are the PN/s I used:
6th Jul 2020 4:51pm |
