Home > Camping, Caravanning and Holidays > Gas Bottle Weights - Full and Empty
Rob99
Alistair wrote:
Rob - are both your bottles part used ?
Yes Alistair, both part used so weighing them at the moment is no help and they don't have gauges Sad
Oh, just noticed, my 1,000th post Very Happy
Do I get a prize Stan ? Laughing 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #550448 15th Apr 2020 9:17pm
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Hi,
you could just buy a TRUMA Gas Bottle Level checking tool.
They work great !
They just use ultrasonic beam to check level of gas bottle, by running it up the side of your bottle a little light will go from green to Red where the bottle is empty that will tell you the level very accurate !
they have them on Ebay for about $100 Aussie dollars.
Hope that helps.
Post #550459 16th Apr 2020 12:41am
Sandyt
What about something like this
https://www.amazon.co.uk/IGT-28Mbar-Regula...mp;sr=8-13
Post #550609 17th Apr 2020 9:21am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
The ultrasonic type is good as it tells where the liquid is (LPG ) the other type only tells how much pressure is in there?
Information: The cylinder holds LPG this is not filled to the top because the liquid requires to change to gas top part of the cylinder.
As the gas is removed (used) the liquid turns to gas and goes down the cylinder, but is replaced with gas until all the liquid has gone and only gas is left, then it runs out, it is at the same pressure until the gas runs out.
The magic happens in the cylinder, not on the little gauge outside that is pressure?
Post #550633 17th Apr 2020 11:07am
RiverBlanche
Hi,
thought it was time for a bit of Thread Resurrection Laughing
well it is that time of year for the Tintents to be coming out of storage, to add a bit more info IF the cylinder has a tare weight stamped on it you can easily add the weight of the liquid ^ Thumbs Up
but
not all suppliers stamp the tare weight (empty weight) on their cylinders and as every cylinder will vary its not an exact process Rolling Eyes
A note of safety Exclamation as already mentioned by Tinman ^ the cylinder has a liquid in it with a head of gas, there is a relief valve built into the valve that works on gas pressure, this is why you should Transport the cylinders in an Upright position if you lay them down the valve is in the liquid and it can not sense any pressure increase
Post #592053 21st Apr 2021 10:21pm
dingg1
Someone needs to learn some physics Laughing
Post #592081 22nd Apr 2021 7:02am
Kot
Thank god my Car runs on diesel Rolling with laughter 2018 SE SDV8 4.4 Byron Blue
Post #592087 22nd Apr 2021 7:46am
Baltic Blue
I’m in my seventies, but I remember Boyles Law from my school days... Rolling with laughter
The volume of a boil is inversely proportional to that of 2 spots Thumbs Up Thumbs Up
Post #592088 22nd Apr 2021 7:52am
RiverBlanche
And who might that be Question and more to the point why Question
Post #592139 22nd Apr 2021 5:58pm
