Home > Camping, Caravanning and Holidays > Gas Bottle Weights - Full and Empty
Rob99
Hi all
I don't have a tin tent yet but have a question about the weight of blue butane gas bottles.
I have 2 bottles which i use for barbecue, both labelled as 15kg but I always have a nightmare trying to decide if they are close to empty or not.
Being a simple soul (no laughter please Rolling Eyes ) it seems to make sense that, if I know the weight of an empty bottle, a full one should be 15kg heavier and a half full one 7.5kg heavier.
Does anyone know the weights or, assuming lots of you with tin tents have bottles galore, would anyone be able to weigh an empty and full bottle for me.
Many thanks Thumbs Up
Rob 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #550411 15th Apr 2020 4:59pm
Baltic Blue
Rob,
I have got 2 7kg Calor Butane gas cylinders.
One empty which weighs a fraction over 7 kg
And a brand new full cylinder which weighs 13kg
The red line.
Post #550417 15th Apr 2020 5:41pm
Rob99
Thanks Mike
I presume its not a simple case of doubling the weight of the 7kg bottle to get to a 15kg one? 2021 D350 Fifty Edition - Carpathian Grey
Post #550418 15th Apr 2020 5:45pm
Baltic Blue
Sorry Rob , I have only got the 7 kg cylinders, but I like you never have been able to tell how much gas was left in each.
Now I will know.
Post #550420 15th Apr 2020 5:52pm
i dont think the gas weighs anything, being lighter than air....
...or does it?
edit..i suppose its in liquid form when it goes in... ... - .- -.
Post #550421 15th Apr 2020 6:00pm
Rob - are both your bottles part used ?
I would have thought you could weigh either a full or empty one to get the benchmark - the difference should be 15kg..... Confused
Post #550422 15th Apr 2020 6:02pm
Baltic Blue
My empty one is definitely empty, and the full one has still got the plastic sealing cap on.
Post #550425 15th Apr 2020 6:07pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, What you also have to consider is the ambient temperature? the LPG boils at an ambient temp that's why you hear a hiss when the gas is used from the cylinder, So if the temperature is low it would appear that you have run out of gas? say a cold night then at around midday when the sun is out you still get some gas out of the cylinder when you had thought it was empty.
Works out the same for filling you only buy gas in litres? The top part of the cylinder is gas the rest is liquid as the gas is used the liquid turns to gas so the weight is measured in the liquid, not the gas.
Post #550426 15th Apr 2020 6:09pm
Hmmm - so 7kg of gas weights 6kg - sounds like a con to me - I'd take it back & complain Laughing
I guess a fully empty cylinder is the only worthwhile reference weight then.....
Post #550427 15th Apr 2020 6:10pm
Tinman
The weight of the cylinder is stamped on the cylinder without gas.
Post #550428 15th Apr 2020 6:12pm
I'm resisting the temptation to go outside to check Rolling with laughter
I'm an amateur and only have BBQ Gas - which has a gauge on the bottle these days.
Post #550429 15th Apr 2020 6:29pm
Baltic Blue
I should add that my luggage scales cost me about £5- £6.
Not exactly “ calibrated” by weights & measures .,
They are only usually used to check our suitcases are within airline allowance.
Post #550432 15th Apr 2020 7:03pm
Tinman
I think they will be collecting a lot of dust in the current climate? Big Cry
Post #550433 15th Apr 2020 7:05pm
You will struggle to fit the bigger bottles in the gas locker.👍🏻 There is nothing that can't be fixed with a hammer😜😜
Post #550437 15th Apr 2020 7:58pm
Fox889
If you go onto the red gas bottles, they have a nifty gauge fitted at the top.
Once upon a time, Calor had 'calor lite' bottles which I was told were coming back into distribution this year but that seems to be incorrect. Calor are apparently looking into another 'lite' design.
As northernmonketjones has said, you'll struggle to store 15kg in a 'van.
 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #550438 15th Apr 2020 8:08pm
