![]() | Home > Technical (L405) > Low battery warning but which battery? |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Do you have a multimeter? |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
Yes |
Disconnect the batteries and test each one, over 12.5v and the battery should be ok, bellow, charge for 24hrs and retest after being left for an hour or so off the charger.
Thanks.
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 928 ![]() ![]() |
Had the same and it was the main battery.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35646 ![]() ![]() |
it will the main battery.... ... - .- -.
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
I've replaced both on mine within the last few months and it still shows low battery after three or four short journeys. Turns out both of the old batteries are still good and holding charge so they've been put to other uses which is fine in my case, but not so good otherwise. A voltage test seems to be the first port of call. |
did you reset the battery on yours Rob when you fitted the new one... ... - .- -.
Yes Stan, in both instances re-set by professional mechanics. I do wonder whether the message appears on the basis of journey duration because as said, the old batteries are fine, and the new batteries should be as well. |
thats my theory out the door then |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Is it reporting a low battery even when its on a charger/charged? |
No Craig.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
If the main batt is only that old then you wouldn’t expect it to be goosed.
So, does it go through a charging cycle? Does it get to the end of charging and tell you it’s charged? And then tell you 24hrs later it’s low? |
