Home > Wheels & Tyres > how to run 35 inch tyres on the L322
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
I am wondering what is the largest wheels and tyres you can fit to the L322?
For context, this is in relation to off road use, not large road wheel's. I am looking to potentially have a secondary set of off road wheels, its the 4.4 TDV8 so it has the larger brembo calipers, so I know the actual wheel size will need to be 20 inch. but wondering what limiting factors there are besides the obvious need to cut and shut the arches to accommodate, and possibly a suspension lift. The L322 is very capable off road especially with locking diffs, so how can I get 35inch tyre to fit?
I managed to get 33 inch tyres on my L405 via some 275 60 20 coopers, however, I would like 35's with plenty of side wall, and maybe even some steel modular wheels. My options as I see it, are to cut out arch, and remove factory intercoolers, for an aftermarket charge cooler, install spacers, lift suspension, and maybe even down size the brakes to some smaller floating 6 piston brakes that will accommodate a 18 inch wheel
Has anyone got any experience or seen this done on the L322? I see lots of pictures of Range rover classics running large wheels P38 etc. but no L322's at all...
Post #548925 31st Mar 2020 8:20am
Post #548941 31st Mar 2020 9:44am
verydisco
Hi
On your TDV8, the wheel size could be as low as 19 inch - hope this helps. Plenty of tyre option in that size and in 20'' statesides. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #548944 31st Mar 2020 9:51am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Plenty of pictures of them with 33” - might suggest 35” is a lot more work.
Post #548952 31st Mar 2020 10:40am
I'd agree - it will be a disproportionately large effort for an extra inch of clearance under the diffs - but you don't seem to be put off by a challenge.....
I went down a similar route with a Jeep TJ which is infinitely easier to modify and it was a complete pain in the number of things that needed changing or uprating. I ended up with a great off roader, that was far less usable on the road.
Post #548956 31st Mar 2020 12:34pm
Charles89
verydisco wrote:
Hi
Are you sure?.... I've researched everywhere, and all I seem to find is that the L405 4.4SDV8 has such large calipers on the front that 20" wheels are the smallest wheels you can get onto it?
Have you tried 19" wheels on yours? I do like the idea of some extra rubber, so if it's a sure thing I will get some 19s ...
Post #549834 10th Apr 2020 7:32am
Charles89
No to phased no... but I am also exploring other options for more lift and clearance. Of course true lift comes from bigger tyres because it's not raising the body. So this is why I was looking to fit 35" tyres
Post #549835 10th Apr 2020 7:34am
Agree - true lift = bigger tyres, but the body will have to rise also - assuming you want to get as much articulation as possible
Some info on the 19's - https://www.fullfatrr.com/forum/topic48293.html
You'd need to check the width also as I'm guessing you'd be running wider tyres ?
Post #549836 10th Apr 2020 7:45am
Charles89
Thanks for the info.. looks like I will need to buy an after market 6 piston caliper set up in a smaller diamiter. I found AP racing brakes that will fit. Thicker vented floating discs, but smaller diameter of 355mm allowing for an 18 inch wheel fitment, rears can then use same calipers but reduce to the 3.0tdi discs and carriers. Then you can fit modular steel wheels 18 inch 9.5J wide with 305 75 18, should make for great off road performance.
I want to do it, but part of me thinks why the hell do I need to Rolling with laughter
I think my biggest issue is wanting somthing as rugged as a hilux with 35" wheels but the refinement and capability of the range rover.
I dont think I'm making it up when I say the L405 is such a capable off road car, but lacks some of the options the discovery and defender have available. Wheel size being one of them.... never has made sense to me to have 20" wheels for off roading. Unless of course you can compensate by having massive tyres, but then arch and suspension interference start to occur.
I'm already looking at options for charge coolers to get rid of the intercoolers so that I can make space in the arches for larger wheels...
My misses shakes her head daily at the crazy ideas i come up with for this car... I think I need to stop watching 4x4 adventure videos on YouTube Laughing
Post #549853 10th Apr 2020 9:13am
Weegie
For information, I have a set of the 501s in Alistair's link with 23/65/29 tyres on them. They were sold as being 405 take offs. They fitted my 2008 Tdv8 with the 4 pot Brembos.
Not sure if that helps you but just to confirm the link.
I did change to 255/55/20s. John
GAP iiD BT
Post #549856 10th Apr 2020 10:04am
GraemeS
Better to fit 275/55R20 than any 19" as there isn't much available in 19" yet lots in 275/55R20 including at least 1 LT. 275/55R20 are barely 32" and fit the L405 without any rubbing.
Post #549858 10th Apr 2020 10:59am
Definitely fit 19” on the 4.4 with the 6 pot brembo.
Here’s a pic of my 4.4 on the only LR 19” which fitted.
Not sure about after market and the there were some D4 19” which also fitted. What won’t fit is the 19”
From the 3.6.
These wheels are now surplus in my garage and will be going in the for sale section after Lockdown, along with some surplus tyres.... There is nothing that can't be fixed with a hammer😜😜
Post #550101 12th Apr 2020 2:19pm
Charles89
PM me a price and maybe if your up for it I can pop over and try one on and take them off your hands Thumbs Up do you have a set of 5?
Post #550110 12th Apr 2020 4:06pm
They aren’t going anywhere until this lockdown is done 👍🏻
Don’t have 5 unfortunately. Old car ran 20” most of the time and I only used these for winters which they still have on. Tyres are scorp winters at 255/55/19, decent tread left.
Not sure on price will have a think. There is nothing that can't be fixed with a hammer😜😜
Post #550117 12th Apr 2020 5:06pm
Charles89
great thanks Smile provided the L322 and L405 brakes are the same size still (I believe they are) then they should fit over the calipers.
Post #550157 13th Apr 2020 7:11am
