Home > Wheels & Tyres > how to run 35 inch tyres on the L322
Weegie
Charles, I believe you have a spare set that fits the 405. If you wanted to measure the inside diameter and the depth I could check it against the 19s I have which are off the car.
Presuming that would give the required information. John
GAP iiD BT
Post #550160 13th Apr 2020 7:49am
Norm
Canada 2008 Range Rover HSE 4.4 V8 Alaska White
Don't bother with 19" wheels, off road tire choice is almost nonexistent, at least here in Canada. If you're going to mess around changing brakes etc. go with 18" wheels for the extra sidewall and much better off road tire choice.
There's a guy in the US on Facebook that makes a L322 lift kit that uses spacers rather than lift rods to archive either a 2" or 3" lift. His kit includes bolts etc. to correct wheel camber etc. I think his kit is about $600, more expensive than rods but in my opinion a much better solution. Worth checking him out https://www.facebook.com/sgcoffroad/posts/520013832047573
Post #550306 14th Apr 2020 1:57pm
