Home > Maintenance & Mods (L322) > Squeaky belt
Fox889
Squeaky belt
Had an annoying squeaky belt the other day, sprayed some brake cleaner on the belt, no difference. Tried WD40 & that cured it for a day but the squeak came back. Speaking to 4x4 Indy Saturday morning, he told me to lift the bonnet & await his 'special stuff"........it cured it instantly, quiet as a mouse. Same the day after, brilliant stuff it is, every workshop & toolbox should have some of this magical cure..........what is it?..............Johnsons Baby talcum powder (other makes are available).
Yep, a quick dousing of talc & the squeaky belt is no more. Apparently, the talc absorbs moisture rather than trying to disperse it with brake cleaner/WD40. Amazing what you can learn Very Happy [/b] 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
Post #547260 15th Mar 2020 9:06pm
Spud
England 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Works for sweaty gonads too! Thumbs Up 2006 4.2 SC
Post #547266 15th Mar 2020 9:34pm
mjdronfield
I take it you have to strip most of the covers off to get the talc where it needs to go? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #547271 15th Mar 2020 10:21pm
DrRob
Mine got so annoying that I had a new tensioner fitted but didn't cure it 100%
Had Rovertune fit new belt and idler when it was on the ramps there.
Tensioner alone sometimes works for folks but not all Thumbs Up
No more canaries! Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #547288 16th Mar 2020 7:53am
Fox889
mjdronfield: nope, just turned the engine off, tapped a little talc in the gap & hey presto, sorted. Took the guy all of 2 minutes. Dare say if you're clever enough you could make yourself some sort of 'blow pipe' & get it right on the belt. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Post #547366 16th Mar 2020 7:54pm
mjdronfield
Brill. Been putting up with mine squeaking for nearly a year. Driving me bonkers.
I can’t remember where the gaps are without looking.
I shall investigate.......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #547389 16th Mar 2020 9:41pm
Fox889
mjdronfield: If you pop the top plastic engine cover off, there's room between the radiator & the engine to squeeze a hand down there, or "aim-squeeze-fire" the talc from above as it where. When he started the engine up there was a slight puff of talc & that was it, quick wipe round with a rag & all's still quiet.
There is a product available from Motor Factors called 'anti belt squeak' but this has, so far, done the job for just a few pennies. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Post #547411 17th Mar 2020 8:00am
